shaun811
(Shaun S Ritchie)
1
I have the SonoffLAN addon / integration and every time I try to update it hangs at around 50% it all my SONOFF equipment goes offline for days.
This is the error in the logs
ogger: homeassistant.setup
Source: setup.py:221
First occurred: 20 February 2024 at 14:14:38 (1 occurrences)
Last logged: 20 February 2024 at 14:14:38
Setup failed for ‘sonoff’: Integration not found.
Tamsy
(Tamsy)
2
Uninstalling/removing the SonoffLAN addon / integration, restarting Home Assistant thereafter and then reinstalling SonoffLAN might help.
shaun811
(Shaun S Ritchie)
3
Will this affect my automations / scenes that use this addon?
aceindy
(Aceindy)
4
Depends a bit if you use devices or entities in your automations.
As long as you use entities and preserve the same names you should be OK
shaun811
(Shaun S Ritchie)
5
I uninstalled it but now it won’t download again. Just spinning circle forever.
Same issue I had with updating it.
Sounds like a problem with either your github account or site. Or a issue with the storage media used in your HA instance.
shaun811
(Shaun S Ritchie)
7
Think I might have changed my github account since I last installed / updated. Where can I update this?
It will most likely be the HACS installation that needs to be removed and readded, then redo anything you’ve installed using HACS.
See: GitHub - hacs/integration: HACS gives you a powerful UI to handle downloads of all your custom needs.
shaun811
(Shaun S Ritchie)
9
Did that and it worked. 3 weeks of not being able to control my Sonoff equipment over.
Thank you
