Updating Stream Deck key colors
I have Streamdeck working well with Home Assistant, using the StreamDeck application running on my machine with WebSockets.
I can display values on the keys and perform actions via Home Assistant on key press.
What I’d like to do is change the color of the text for a value in a key; for example, I have a fridge temperature which is generally between 3.6 and 4.0 degrees. The text is white on black, I want the text to be blue if value < 3.6 and red if > 4.0
Has anyone done this, or does anyone know if this can be done?
Thanks!
Would be great to hear if you found a solution to this. I have a few buttons with status on, and I would really like to change the colors to match the status.
No, but I do think about trying it out again every so often!
If you do find out, feel free to share :slight_smile:
