Every time I try to use ESPHome or the build-in HA update mechanism to update my esp32-s3-box after an ESPHome update, the esp-s3-box update fails. I’m guessing based on metrics during the update my 2GB HA Yellow is running out of RAM; but that’s just a guess.
Great question. The logs from the device update specifically are:
INFO ESPHome 2024.3.0
INFO Reading configuration /config/esphome/esp32-s3-box-fd12c4.yaml...
INFO Updating https://github.com/esphome/firmware.git@main
INFO Updating https://github.com/esphome/esphome.git@pull/5230/head
WARNING GPIO0 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO45 is a strapping PIN and should only be used for I/O with care.
INFO Generating C++ source...
INFO Updating https://github.com/espressif/[email protected]
INFO Updating submodules (components/esp-sr, components/esp-adf-libs) for https://github.com/espressif/[email protected]
INFO Updating https://github.com/espressif/esp-tflite-micro@None
INFO Compiling app...
Processing esp32-s3-box-fd12c4 (board: esp32s3box; framework: espidf; platform: platformio/[email protected])
HARDWARE: ESP32S3 240MHz, 320KB RAM, 16MB Flash
- framework-espidf @ 3.40406.240122 (4.4.6)
- tool-cmake @ 3.16.9
- tool-ninja @ 1.10.2
- toolchain-esp32ulp @ 2.35.0-20220830
- toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
- toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch5
Reading CMake configuration...
Dependency Graph
|-- Improv @ 1.2.3
|-- noise-c @ 0.1.4
Compiling .pioenvs/esp32-s3-box-fd12c4/src/esphome/components/esp_adf/speaker/esp_adf_speaker.o
Compiling .pioenvs/esp32-s3-box-fd12c4/src/esphome/components/improv_serial/improv_serial_component.o
Compiling .pioenvs/esp32-s3-box-fd12c4/src/esphome/components/ledc/ledc_output.o
Compiling .pioenvs/esp32-s3-box-fd12c4/src/esphome/components/light/addressable_light.o
Maybe this is a RTFM situation, and if so I apologize, but is there a relatively easy way to remotely update a ESP home device from a non Home Assistant machine? I have many machines with +8/16 GB of RAM that would probably be a better fit than the 2GB Home Assistant Yellow base station.
Well this is awesome, this option totally escaped me as I have been happily using the Home Assistant Add-on.
I’m still of the strong suspicion that I will need/want to upgrade my Home Assistant Yellow to an 8GB CM4 board, but maybe I can put that off for a while. Thanks, this gives me a starting point!
I wouldn’t change the Yellow right now, you should first investigate a little further. I have some voice assistants running with ESPHome, they compile fine with 2GB RAM on a Pi4 (just tested, not my real installation).
The problem seems to be more related to the use of CPU power, than RAM. ESPHome can work with less RAM, but it pushes the CPU to its limits. This is only for a few seconds, but it’s sometimes enough to let the CPU freeze.
Would you mind posting your YAML for that device, so we can take a look and maybe find some things to optimize?
But for the future, it wouldn’t be a bad idea to set some money aside to get something better. I personally am a big fan of these little PCs that could run Proxmox and HA-OS in a VM. I have a pre-owned pre-loved Lenovo ThinkCentre and am really happy with it!
Just for reference, this is the direct link to the file you’re installing, so you can see, what really happens in your configuration:
But that is a file, that’s not that easy for ESPHome. If you compare it with the config for the small M5Stack Atoms, it’s huge. It has more than double the lines (sure, line numbers doesn’t mean anything), and there is a lot more to compile, starting with the pictures and so on.
8GB are nice, but really not necessary. I’d go with 4GB, because these really are just peaks. HA in general (HA-OS) takes whatever RAM you throw at it, give it 8GB and it uses 8GB.
As I said, it’s not a RAM question, more a CPU power question. I’m quite sure, 4GB are more than enough, but if you could up your CPU, that would make a difference.
As I said, these mini-PCs are quite nice, or if you want to go higher, look for a NUC. Both variants are relatively cheap to get on eBay as a pre-loved device.
I just wanted to mention that I had to increase the RAM of the HA VM from 4GB to 6GB for the build to work and not get massively stuck. I am using esphome as an add-on in HA. My guess is that you need free 4GB when building this. Also, try a VM/machine restart before the build. It might help to run the build with a clean slate.
What I wound up doing: I installed esphome via pip/venv into an /espaway directory (get it?) on an 8GB raspberry pi, moved all my .yaml files for my esphome devices into the project directory, and then wrote a bash script called upgrade.sh in the same directory:
