Ha! Yes I have a broadlink and the thing is a pain in the butt. I’ll comment that out, test, and report back. Thank you!!!
I owe you a coffee!! .61 is installed. According to info panel I am on 0.61.0
I wasn’t able to install that terminal or ssh add-on but I was able to downgrade via the Hass Configurator. It has an execute shell command under the right menu. It’s a bit silly but it does the job!
Steps:
- execute: apk update
- execute: apk add curl
- create file (downgrade) with the downgrade command as the contents:
curl -d ‘{“version”: “0.60.1”}’ http://hassio/homeassistant/update - execute: sh downgrade
I ran “ps -efa” a couple of times after the “sh downgrade”. This is to check if the command is still running. That command should take a while to finish. Maybe around 2 mins.
I can confirm that This work thanks mate
i can confirm that with update supervisor first the update works fine
urr how do i use this on windows?
I used the HASSIO Termianl (https://github.com/hassio-addons/addon-terminal) to run that command. Others got it done by connecting inside the HASSIO docker image (so, ssh into docker) and running that command.
Thanks @mrpinapple ! Using the github file, restored the hassio tab.
Setting up SSH is really annoying stuff.
Using Mac OS (see: here) the following lines did the job for me:
ssh-keygen -t rsa -b 4096 -C “[email protected]”
chmod 600 private_key_file
ssh -i private_key_file [email protected]
I’m still missing recorder, logbook and history and getting this error at startup:
Tue Jan 16 2018 16:48:01 GMT+0100 (CET)
Error during connection setup: (sqlite3.DatabaseError) file is not a database (Background on this error at: Error Messages — SQLAlchemy 2.0 Documentation) (retrying in 3 seconds)
edit:
Removed the home-assistant_v2.db file from the /config/ dir. Error disappeared. What a day to start with Hass.io…
edit2:
Pushbullet notification is broken in 0.61
nice, but i cant access my hass.io over https://192.168.X.XX:8123/ cause i already tried to install the bugged version 0.61… oh dear i dont have a hdmi cable around
Same Problem here, disabled “platform: broadlink” and it works…
# LG 55UC970V
#- platform: broadlink
# update_interval: 60
# host: 10.1.2.23
# mac: '34:EA:34:8E:E7:91'
# type: rm_mini
# timeout: 15
# switches:
# tvlgpower:
# command_on: 'JgBYAAABIJISExETETcSEhISEhQQFBETETcROBESEjcRNhM1EjcTNRMTERISNxEUERMSExE2EjYSNhM2EhIROBE3ETcREhITEgAFGwABH0oSAAwzAAEfShEADQU='
# command_off: 'JgBQAAABJZUUERMSEzYTEhMSERQSExAUFDUTNhQREDsTNhI2FDYUNRMUDxUTEQ86EhMQFBMSEhMROBI4EjcRExI4ETgRORA6EQAFIgABJUwRAA0FAAAAAAAAAAA='
Some may have missed this post. I didn’t have to downgrade to 60.1, I just turned off power to the RPi 3 and then re-powered. Hassio came back with the new supervisor and version 61 working (with Hassio tab).
I hit upgrade in the Hass.io menu section and I got stuck. Luckily I could log in using the SSH add-on. All I did was ‘hassio s update’ and ‘hassio ho reboot’. And voila the frontend came back on with version 0.61dev0.
I had the same issue but then I did a hard reset and it seems to work fine.
I copied and pasted this command into the command_line.txt
file on the Resin OS installed card itself.
`curl -d ‘{“version”: “0.60.1”}’ http://hassio/homeassistant/update`
I restarted the device and the menu has reappeared without using SSH or Samba.
can i reset my hassio without reaching the UI and no hdmi cable, and using windows? is there something i could do by using pyton? or do i have to reinstall all of my stuff? (and load backup)
Just yank the power.
I updated but the version number is still showing as 0.61.0.dev0. Is this normal?
I kept restarting from the GUI (missing HASS.IO after update to .61)… followed the advice to pull the power and now back in business, thanks all!
I think so. I have the same version. All ok here now. My steps:
First I downgraded, than I updated the supervisor and after that I upgraded Hassio.
And I did ‘hassio host reboot’ (using ssh) in between.
Are we safe to do the upgrade to 0.61 now?
