Hi, i haven’t updated Homeassistant for too long. I have Homeassistant Blue, installed version of core is 2024.4.4 but while trying to update to 2024.10.4 it stops after few minutes. I have also tried to update through CLI but same resaults. I also have sem Systemd Journal error which has been for many months not sure if that is related.
Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/odroid-n2-homeassistant:2024.10.4/json: Not Found ("No such image: ghcr.io/home-assistant/odroid-n2-homeassistant:2024.10.4")
2024-10-28 13:25:03.641 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
2024-10-28 13:25:59.495 ERROR (MainThread) [supervisor.host.logs] No systemd-journal-gatewayd Unix socket available
2024-10-28 13:25:59.495 ERROR (MainThread) [supervisor.api] Failed to get supervisor logs using advanced_logs API
SOLVED
Turns out having 1 gb of free space is not enough. Saw that space was running out during update. After trying again with 2gb free space the update went through.
