OK – so I found what i thought would be a solution on this forum, but i still can’t get this working so I thought i’d try a new post. (Running home assistant in docker on Ubuntu)
I have a good number of Z-Wave devices and I really, REALLY don’t want to delete my config and reinstall it.
I’m using the HUBZ Smart Home Controller with ZWave and Zigbee. Originally, the path for ZWave was /dev/ttyUSB1 (and Zigbee was /dev/ttyUSB2). Recently (today), I did a restart and the path changed to /dev/ttyUSB0 and /dev/ttyUSB1, respectively.
So obviously, i want to change this path but i set this up through the home assistant UI and not configuration.yaml. The post i linked too above had what i thought would be the solution i needed.
I did a sudo nano .storage/core.config_entries
and changed the paths here. It doesn’t appeared to have worked though, as these are my logs.
Any suggestions on where else this change should be made or how to update my path of an existing zwave (and zigbee) config?
2020-09-18 22:28:06.890 Always, OpenZwave Version 1.4.3469 Starting Up
2020-09-18 22:28:18.886 Info, Setting Up Provided Network Key for Secure Communications
2020-09-18 22:28:18.888 Info, mgr, Added driver for controller /dev/ttyUSB0
2020-09-18 22:28:18.891 Info, Opening controller /dev/ttyUSB0
2020-09-18 22:28:18.892 Info, Trying to open serial port /dev/ttyUSB0 (attempt 1)
2020-09-18 22:28:18.921 Info, Serial port /dev/ttyUSB0 opened (attempt 1)
2020-09-18 22:28:18.921 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-09-18 22:28:18.921 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-09-18 22:28:18.921 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-09-18 22:28:18.921 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-09-18 22:28:18.921 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-09-18 22:28:18.921 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-09-18 22:28:18.930 Detail, Unsolicited message received while waiting for ACK.
2020-09-18 22:28:18.930 Detail, contrlr, Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x34, 0x2e, 0x30, 0x35, 0x00, 0x01, 0x97
2020-09-18 22:28:18.930 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2020-09-18 22:28:18.930 Info, contrlr, Static Controller library, version Z-Wave 4.05
2020-09-18 22:28:18.930 Detail, Node045, Expected reply was received
2020-09-18 22:28:18.930 Detail, Node045, Message transaction complete
2020-09-18 22:28:18.930 Detail, contrlr, Removing current message
2020-09-18 22:28:18.930 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-09-18 22:28:18.975 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x05, 0x08, 0xf7
2020-09-18 22:28:18.975 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2020-09-18 22:28:18.975 Info, contrlr, There is no SUC ID Server (SIS) in this network.
2020-09-18 22:28:18.975 Info, contrlr, The PC controller is a primary controller.
2020-09-18 22:28:28.932 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-18 22:28:28.932 Detail, contrlr, Removing current message
2020-09-18 22:28:28.932 Detail, contrlr, Notification: Notification - TimeOut
2020-09-18 22:28:28.932 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-09-18 22:28:29.079 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x00, 0x1d, 0xf1, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0x34
2020-09-18 22:28:29.079 Fatal, Failed to get HomeID or Controller Node ID during Init Sequence, m_homeId = 0x00000000, m_Controller_nodeId = 255
2020-09-18 22:28:29.079 Detail, Notification: DriverFailed
