I installed the update this morning. I got a message that some integrations need a restart, that repair failed. I restarted and then rebooted the appliance, but I still get the old version! The logs don’t make me any wiser… Any tips?
The version is displayed correctly, only the interface is the old one. Do I need a frontend reload ?
Home Assistant 2023.6.0
Supervisor 2023.06.1
Operating System 10.2
Frontend 20230607.0 - latest
2023-06-08 09:54:26.788 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2023-06-08 09:55:29.539 WARNING (MainThread) [homeassistant.components.binary_sensor] Setup of binary_sensor platform fritz is taking over 10 seconds.
2023-06-08 09:55:35.100 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: fritz, binary_sensor.fritz
2023-06-08 09:56:09.333 WARNING (MainThread) [hass_nabucasa.iot] Connection closed: Cannot write to closing transport
2023-06-08 09:56:09.443 ERROR (MainThread) [homeassistant.components.synology_dsm.coordinator] Unexpected error fetching 192.168.1.5 SynologyDSMCameraUpdateCoordinator data: {'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'TimeoutError'}
File "/usr/local/lib/python3.11/site-packages/synology_dsm/synology_dsm.py", line 317, in _execute_request
response = await self._session.get(url_encoded, **kwargs)
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 560, in _request
await resp.start(conn)
File "/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 899, in start
message, payload = await protocol.read() # type: ignore[union-attr]
File "/usr/local/lib/python3.11/site-packages/aiohttp/streams.py", line 616, in read
await self._waiter
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.11/site-packages/synology_dsm/synology_dsm.py", line 316, in _execute_request
async with async_timeout.timeout(self._timeout):
File "/usr/local/lib/python3.11/site-packages/async_timeout/__init__.py", line 129, in __aexit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.11/site-packages/async_timeout/__init__.py", line 212, in _do_exit
raise asyncio.TimeoutError
TimeoutError
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 283, in _async_refresh
self.data = await self._async_update_data()
File "/usr/src/homeassistant/homeassistant/components/synology_dsm/coordinator.py", line 127, in _async_update_data
await surveillance_station.update()
File "/usr/local/lib/python3.11/site-packages/synology_dsm/api/surveillance_station/__init__.py", line 25, in update
raw_data = await self._dsm.get(self.CAMERA_API_KEY, "List", max_version=7)
File "/usr/local/lib/python3.11/site-packages/synology_dsm/synology_dsm.py", line 207, in get
return await self._request("GET", api, method, params, **kwargs)
File "/usr/local/lib/python3.11/site-packages/synology_dsm/synology_dsm.py", line 282, in _request
response = await self._execute_request(request_method, url, params, **kwargs)
File "/usr/local/lib/python3.11/site-packages/synology_dsm/synology_dsm.py", line 358, in _execute_request
raise SynologyDSMRequestException(exp) from exp
synology_dsm.exceptions.SynologyDSMRequestException: {'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'TimeoutError'}
2023-06-08 09:56:09.521 ERROR (MainThread) [homeassistant.components.synology_dsm.coordinator] Unexpected error fetching 192.168.1.5 SynologyDSMSwitchUpdateCoordinator data: {'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'TimeoutError'}
await self._waiter
TimeoutError
File "/usr/src/homeassistant/homeassistant/components/synology_dsm/coordinator.py", line 73, in _async_update_data
"switches": {"home_mode": await surveillance_station.get_home_mode_status()}
File "/usr/local/lib/python3.11/site-packages/synology_dsm/api/surveillance_station/__init__.py", line 153, in get_home_mode_status
raw_data = await self._dsm.get(self.HOME_MODE_API_KEY, "GetInfo")
2023-06-08 09:56:09.750 ERROR (MainThread) [homeassistant.components.esphome.dashboard] Error requesting ESPHome Dashboard data: Cannot connect to host 127.0.0.1:65281 ssl:default [Connect call failed ('127.0.0.1', 65281)]
2023-06-08 09:56:40.854 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/netatmo/__init__.py", line 206, in register_webhook
webhook_register(
File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 53, in async_register
raise ValueError("Handler is already defined!")
ValueError: Handler is already defined!
2023-06-08 10:04:45.862 WARNING (MainThread) [homeassistant.helpers.entity] Update of update.home_assistant_core_update is taking over 10 seconds```
And another reload and everything is fine… Some timeouts and not enough patience I guess
