requirements txt looks like
pandas
influxdb
pylama
I also tried just pandas and pandas==1.0.5 for an earlier version
the error log is really really long 600+ lines so here is the error part
copying pandas/core/arrays/sparse/accessor.py -> build/lib.linux-x86_64-3.8/pandas/core/arrays/sparse
creating build/lib.linux-x86_64-3.8/pandas/io/formats/templates
copying pandas/io/formats/templates/html.tpl -> build/lib.linux-x86_64-3.8/pandas/io/formats/templates
UPDATING build/lib.linux-x86_64-3.8/pandas/_version.py
set build/lib.linux-x86_64-3.8/pandas/_version.py to '1.1.1'
running build_ext
building 'pandas._libs.algos' extension
creating build/temp.linux-x86_64-3.8
creating build/temp.linux-x86_64-3.8/pandas
creating build/temp.linux-x86_64-3.8/pandas/_libs
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs -Ipandas/_libs/src/klib -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/algos.c -o build/temp.linux-x86_64-3.8/pandas/_libs/algos.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/algos.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/algos.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.groupby' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/groupby.c -o build/temp.linux-x86_64-3.8/pandas/_libs/groupby.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/groupby.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/groupby.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.hashing' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/hashing.c -o build/temp.linux-x86_64-3.8/pandas/_libs/hashing.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/hashing.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/hashing.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.hashtable' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -Ipandas/_libs/src/klib -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/hashtable.c -o build/temp.linux-x86_64-3.8/pandas/_libs/hashtable.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/hashtable.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/hashtable.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.index' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs/tslibs -Ipandas/_libs/src/klib -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/index.c -o build/temp.linux-x86_64-3.8/pandas/_libs/index.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/index.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/index.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.indexing' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/indexing.c -o build/temp.linux-x86_64-3.8/pandas/_libs/indexing.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/indexing.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/indexing.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.internals' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/internals.c -o build/temp.linux-x86_64-3.8/pandas/_libs/internals.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/internals.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/internals.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.interval' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs/tslibs -Ipandas/_libs/src/klib -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/interval.c -o build/temp.linux-x86_64-3.8/pandas/_libs/interval.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/interval.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/interval.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.join' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -Ipandas/_libs/src/klib -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/join.c -o build/temp.linux-x86_64-3.8/pandas/_libs/join.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/join.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/join.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.lib' extension
creating build/temp.linux-x86_64-3.8/pandas/_libs/src
creating build/temp.linux-x86_64-3.8/pandas/_libs/src/parser
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -Ipandas/_libs -I./pandas/_libs/tslibs -I./pandas/_libs -Ipandas/_libs/src/klib -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/lib.c -o build/temp.linux-x86_64-3.8/pandas/_libs/lib.o -Werror
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -Ipandas/_libs -I./pandas/_libs/tslibs -I./pandas/_libs -Ipandas/_libs/src/klib -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/src/parser/tokenizer.c -o build/temp.linux-x86_64-3.8/pandas/_libs/src/parser/tokenizer.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/lib.o build/temp.linux-x86_64-3.8/pandas/_libs/src/parser/tokenizer.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/lib.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.missing' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs/tslibs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/missing.c -o build/temp.linux-x86_64-3.8/pandas/_libs/missing.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/missing.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/missing.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.parsers' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs -Ipandas/_libs/src/klib -Ipandas/_libs/src -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/parsers.c -o build/temp.linux-x86_64-3.8/pandas/_libs/parsers.o -Werror
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs -Ipandas/_libs/src/klib -Ipandas/_libs/src -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/src/parser/tokenizer.c -o build/temp.linux-x86_64-3.8/pandas/_libs/src/parser/tokenizer.o -Werror
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs -Ipandas/_libs/src/klib -Ipandas/_libs/src -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/src/parser/io.c -o build/temp.linux-x86_64-3.8/pandas/_libs/src/parser/io.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/parsers.o build/temp.linux-x86_64-3.8/pandas/_libs/src/parser/tokenizer.o build/temp.linux-x86_64-3.8/pandas/_libs/src/parser/io.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/parsers.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.reduction' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/reduction.c -o build/temp.linux-x86_64-3.8/pandas/_libs/reduction.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/reduction.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/reduction.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.ops' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/ops.c -o build/temp.linux-x86_64-3.8/pandas/_libs/ops.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/ops.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/ops.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.ops_dispatch' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/ops_dispatch.c -o build/temp.linux-x86_64-3.8/pandas/_libs/ops_dispatch.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/ops_dispatch.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/ops_dispatch.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.properties' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/properties.c -o build/temp.linux-x86_64-3.8/pandas/_libs/properties.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/properties.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/properties.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.reshape' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/reshape.c -o build/temp.linux-x86_64-3.8/pandas/_libs/reshape.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/reshape.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/reshape.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.sparse' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/sparse.c -o build/temp.linux-x86_64-3.8/pandas/_libs/sparse.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/sparse.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/sparse.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslib' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs/tslibs -I./pandas/_libs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslib.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslib.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslib.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslib.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslibs.base' extension
creating build/temp.linux-x86_64-3.8/pandas/_libs/tslibs
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/base.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/base.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/base.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslibs/base.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslibs.ccalendar' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/ccalendar.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/ccalendar.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/ccalendar.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslibs/ccalendar.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslibs.dtypes' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/dtypes.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/dtypes.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/dtypes.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslibs/dtypes.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslibs.conversion' extension
creating build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/src
creating build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/src/datetime
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs/tslibs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/conversion.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/conversion.o -Werror
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs/tslibs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/src/datetime/np_datetime.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/src/datetime/np_datetime.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/conversion.o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/src/datetime/np_datetime.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslibs/conversion.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslibs.fields' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs/tslibs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/fields.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/fields.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/fields.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslibs/fields.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslibs.nattype' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs/tslibs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/nattype.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/nattype.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/nattype.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslibs/nattype.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslibs.np_datetime' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -Ipandas/_libs/tslibs -I./pandas/_libs/tslibs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/np_datetime.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/np_datetime.o -Werror
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -Ipandas/_libs/tslibs -I./pandas/_libs/tslibs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/src/datetime/np_datetime.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/src/datetime/np_datetime.o -Werror
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -Ipandas/_libs/tslibs -I./pandas/_libs/tslibs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/src/datetime/np_datetime_strings.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/src/datetime/np_datetime_strings.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/np_datetime.o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/src/datetime/np_datetime.o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/src/datetime/np_datetime_strings.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslibs/np_datetime.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslibs.offsets' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs/tslibs -Ipandas/_libs/tslibs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/offsets.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/offsets.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/offsets.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslibs/offsets.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslibs.parsing' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -Ipandas/_libs/tslibs -Ipandas/_libs/src/klib -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/parsing.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/parsing.o -Werror
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -Ipandas/_libs/tslibs -Ipandas/_libs/src/klib -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/src/parser/tokenizer.c -o build/temp.linux-x86_64-3.8/pandas/_libs/src/parser/tokenizer.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/parsing.o build/temp.linux-x86_64-3.8/pandas/_libs/src/parser/tokenizer.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslibs/parsing.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslibs.period' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -Ipandas/_libs/tslibs -I./pandas/_libs/tslibs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/period.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/period.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/period.o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/src/datetime/np_datetime.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslibs/period.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslibs.strptime' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs/tslibs -Ipandas/_libs/tslibs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/strptime.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/strptime.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/strptime.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslibs/strptime.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslibs.timedeltas' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs/tslibs -Ipandas/_libs/tslibs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/timedeltas.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/timedeltas.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/timedeltas.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslibs/timedeltas.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslibs.timestamps' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs/tslibs -Ipandas/_libs/tslibs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/timestamps.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/timestamps.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/timestamps.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslibs/timestamps.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslibs.timezones' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/timezones.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/timezones.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/timezones.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslibs/timezones.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslibs.tzconversion' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs/tslibs -Ipandas/_libs/tslibs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/tzconversion.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/tzconversion.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/tzconversion.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslibs/tzconversion.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.tslibs.vectorized' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs/tslibs -Ipandas/_libs/tslibs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/tslibs/vectorized.c -o build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/vectorized.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/tslibs/vectorized.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/tslibs/vectorized.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.testing' extension
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -I./pandas/_libs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/testing.c -o build/temp.linux-x86_64-3.8/pandas/_libs/testing.o -Werror
gcc -shared -Wl,--strip-all build/temp.linux-x86_64-3.8/pandas/_libs/testing.o -L/usr/local/lib -o build/lib.linux-x86_64-3.8/pandas/_libs/testing.cpython-38-x86_64-linux-gnu.so
building 'pandas._libs.window.aggregations' extension
creating build/temp.linux-x86_64-3.8/pandas/_libs/window
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DNPY_NO_DEPRECATED_API=0 -Ipandas/_libs/window -I./pandas/_libs -I/tmp/pip-build-env-vpj5_mz3/overlay/lib/python3.8/site-packages/numpy/core/include -I/usr/local/include/python3.8 -c pandas/_libs/window/aggregations.cpp -o build/temp.linux-x86_64-3.8/pandas/_libs/window/aggregations.o -Werror
gcc: fatal error: cannot execute 'cc1plus': execvp: No such file or directory
compilation terminated.
error: command 'gcc' failed with exit status 1
ERROR: Failed building wheel for pandas
so it works fine without the requiments ,but I have a lot of apps that use pandas and numpy. I could probably rewrite the numpy ones ,but the pandas ones are pretty essential to analyzing and graphing all my data.
