Im running home assistant on raspberry pi 4, 8gb. Home assistant OS 7.2
When updating core 2021.12.10 → 2022.2.2 afterwards de webgui is not reachable anymore and doesn’t work. Command line is still active. Also the home asistant observer, same ip, port 4357 is reachable. Core logs attached.
What to do? What cause the problem and how to fix. I am quite new to this debugging.
Resotore backups to 2021.12.10 does fix the HA. However when updating again it is broken. Also do a clean install and all updates, afterwards restore the backup does the HA cause not working anymore.
The error i get when approaching the webui on port 8123 and the HA specific IP (as per command line visible)
#site not reachable
Deze site is niet bereikbaar
192.168.1.xx heeft de verbinding geweigerd. 192.168.1.xx has refused connection.
ERR_CONNECTION_REFUSED
Apart from a clean install, what are the options to do?
Same issue here. Since update.
First time my HA was inaccessible ever!
I had to physically shut down Pi (Pi4 8gb), and it rebooted. Now accessible again.
This update seems to have caused me more hassle than ever!
I think this issues has to do with the new upnp integration.
See: https://github.com/home-assistant/core/issues/65337#issuecomment-1029969441
But I’m not sure about anything anymore!
Hi All,
my upgrade installed properly, anyhow my Gosund Sp111 integration is not longer supported.
The Konfiguration check also statetes many time (many devices):
Invalid config for [light.mqtt]: [value_template] is an invalid option for [light.mqtt]. Check: light.mqtt->value_template. (See ?, line ?).
Thank you for your guidance.
I read the nints but found …" (tasmota-lite.bin does not support this integration)."…
We run the light on more than 10 Gosund SP111 devices.
Will try again if the device accept full version now (memory…).
Not to you but in gerneral:
This was working proper for years now, why is it changed and why could I not find a hint in the release notes at all (only Zwave Lights are found in release note)?
I try to upgrad my Tasmota accordingly and try to find the right integraton.
THX Again for the perspective and your support
Would spend a coffee if I get it poper to work.
Michael
