pi@raspberrypi:~ $ sudo systemctl stop [email protected]
pi@raspberrypi:~ $ sudo su -s /bin/bash homeassistant
homeassistant@raspberrypi:/home/pi $ source /srv/homeassistant/bin/activate
(homeassistant) homeassistant@raspberrypi:/home/pi $ pip3 install --upgrade homeassistant
File "/srv/homeassistant/bin/pip3", line 7, in <module>
from pip import main
File "/srv/homeassistant/lib/python3.4/site-packages/pip/__init__.py", line 28, in <module>
from pip.vcs import git, mercurial, subversion, bazaar # noqa
File "/srv/homeassistant/lib/python3.4/site-packages/pip/vcs/subversion.py", line 9, in <module>
from pip.index import Link
File "/srv/homeassistant/lib/python3.4/site-packages/pip/index.py", line 33, in <module>
from pip._vendor import html5lib, requests, six
File "/srv/homeassistant/lib/python3.4/site-packages/pip/_vendor/html5lib/__init__.py", line 16, in <module>
from .html5parser import HTMLParser, parse, parseFragment
File "/srv/homeassistant/lib/python3.4/site-packages/pip/_vendor/html5lib/html5parser.py", line 11, in <module>
from . import _inputstream
File "/srv/homeassistant/lib/python3.4/site-packages/pip/_vendor/html5lib/_inputstream.py", line 13, in <module>
from . import _utils
File "/srv/homeassistant/lib/python3.4/site-packages/pip/_vendor/html5lib/_utils.py", line 9, in <module>
import xml.etree.cElementTree as default_etree
File "/usr/lib/python3.4/xml/etree/cElementTree.py", line 3, in <module>
from xml.etree.ElementTree import *
File "<frozen importlib._bootstrap>", line 2237, in _find_and_load
File "<frozen importlib._bootstrap>", line 2226, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 1200, in _load_unlocked
File "<frozen importlib._bootstrap>", line 1129, in _exec
File "<frozen importlib._bootstrap>", line 1467, in exec_module
File "<frozen importlib._bootstrap>", line 1570, in get_code
File "<frozen importlib._bootstrap>", line 656, in _compile_bytecode
ValueError: bad marshal data (invalid reference)
This may help also:
Ok,I test tomorrow, thank you
Hi everybody,
unfortunately I’ve got exactly the same issue when I try to upgrade (I’m in 0.45) hassbian…
I followed this :
cd /srv/hass/lib/python3.4/site-packages/homeassistant
sudo find . -name "*.pyc" -type f -delete
cd /srv/hass/lib/python3.4/site-packages/pytz/
After this I can upgrade HA, but nothings work… Wemo is out, zwave is out, and other stuffs don’t work…
A reinstallation would be complicated because I’ve got a lot of things (Nginx + certificate, dash buttons, zwave, …)
Do you have a solution ?
thank you !
Finally, I had no solution…
So I reinstalled everything !
