Anyone else having this issue? Trying to upgrade form 0.108.9 to 0.109.6 on debian 10 buster on a raspberry pi 3+ using virtualenv , Python 3.7.3, and getting this…
Collecting cryptography==2.9 [17/56] Using cached cryptography-2.9.tar.gz (517 kB) Installing build dependencies ... error ERROR: Command errored out with exit status 1: command: /srv/homeassistant/bin/python3 /srv/homeassistant/lib/python3.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-f4za0l_u/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.8,!=1.11.3; platform_python_implementation != '"'"'PyPy'"'"'' cwd: None Complete output (44 lines): Traceback (most recent call last): File "/usr/local/lib/python3.7/runpy.py", line 193, in _run_module_as_main "__main__", mod_spec) File "/usr/local/lib/python3.7/runpy.py", line 85, in _run_code exec(code, run_globals) File "/srv/homeassistant/lib/python3.7/site-packages/pip/__main__.py", line 26, in <module> sys.exit(_main()) File "/srv/homeassistant/lib/python3.7/site-packages/pip/_internal/cli/main.py", line 73, in main command = create_command(cmd_name, isolated=("--isolated" in cmd_args)) File "/srv/homeassistant/lib/python3.7/site-packages/pip/_internal/commands/__init__.py", line 104, in create_command module = importlib.import_module(module_path)
File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/srv/homeassistant/lib/python3.7/site-packages/pip/_internal/commands/install.py", line 24, in <module>
from pip._internal.cli.req_command import RequirementCommand, with_cleanup
File "/srv/homeassistant/lib/python3.7/site-packages/pip/_internal/cli/req_command.py", line 16, in <module>
from pip._internal.index.package_finder import PackageFinder
File "/srv/homeassistant/lib/python3.7/site-packages/pip/_internal/index/package_finder.py", line 21, in <module>
from pip._internal.index.collector import parse_links
File "/srv/homeassistant/lib/python3.7/site-packages/pip/_internal/index/collector.py", line 14, in <module>
from pip._vendor import html5lib, requests
File "/srv/homeassistant/lib/python3.7/site-packages/pip/_vendor/requests/__init__.py", line 114, in <module>
from . import utils
File "/srv/homeassistant/lib/python3.7/site-packages/pip/_vendor/requests/utils.py", line 25, in <module>
from . import certs
File "/srv/homeassistant/lib/python3.7/site-packages/pip/_vendor/requests/certs.py", line 15, in <module>
from pip._vendor.certifi import where
File "/srv/homeassistant/lib/python3.7/site-packages/pip/_vendor/certifi/__init__.py", line 1, in <module>
from .core import contents, where
File "/srv/homeassistant/lib/python3.7/site-packages/pip/_vendor/certifi/core.py", line 12, in <module>
from importlib.resources import read_text
File "/usr/local/lib/python3.7/importlib/resources.py", line 11, in <module>
from typing import Iterable, Iterator, Optional, Set, Union # noqa: F401
File "/srv/homeassistant/lib/python3.7/site-packages/typing.py", line 1357, in <module>
class Callable(extra=collections_abc.Callable, metaclass=CallableMeta):
File "/srv/homeassistant/lib/python3.7/site-packages/typing.py", line 1005, in __new__
self._abc_registry = extra._abc_registry
AttributeError: type object 'Callable' has no attribute '_abc_registry'
ERROR: Command errored out with exit status 1: /srv/homeassistant/bin/python3 /srv/homeassistant/lib/python3.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-f4za0l_u/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.8,!=1.11.3; platform_python_implementation != '"'"'PyPy'"'"'' Check the logs for full command output.
