Upgrade Failure - 2024.10.4 OOM, Rollback
Hi all,
Running into an issue where I cannot update HA past 10.4, core boots then Supervisor decides that it is no longer running and terminates & rolls back. Having issues finding logging that will actually help. Running HAOS on Hyper-V, latest 14.0 with 5gb of ram allocated.
I have tried:
  • Upgrading manually to every version of 2024.11 and 2024.12
  • Entirely remade the VM - downloaded HAOS vhdx, and restored from a full backup
  • Disabled numerous add-ons and integrations, then upgraded to no avail
  • Repair of supervisor, restart and reboot
I’ve exhausted my know-how for this, was hoping someone could help troubleshoot!
I have added to my configuration.yaml:
homeassistant:
  debug: true
home-assistant.log.fault is empty, and there don’t seem to be any relevant logs in the core.
When updating from CLI:
Out of memory: Killed process 28845 (python3) total-vm:10318920kB, anon-rss 3776684kB, file-rss:128kB, shmem-rss:0kB, UID:0 pgtables:11184kB oom_score_adj:-300
Supervisor log:
2024-12-18 13:40:12.409 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/core/state: Cannot connect to host 172.30.32.1:8123 ssl:False [Connect call failed ('172.30.32.1', 8123)]
2024-12-18 13:40:17.414 ERROR (MainThread) [supervisor.homeassistant.core] Home Assistant has crashed!
2024-12-18 13:40:17.415 CRITICAL (MainThread) [supervisor.homeassistant.core] HomeAssistant update failed -> rollback!
Supervisor log:
Following up - after trial and error, found out the Lidarr integration caused this.
Did you disable Lidarr then perform the upgrade? I have the same issue. Wish there was better logging or error trapping so a failed integration doesn’t take the UI down with no error.
Agreed!
I opted to entirely remove the integration. I then added it back to see what would happen - crashed my HA instance entirely. Going to try to scrape together some debug logging and make a bug report.
Experienced same when testing the Lidarr integration as well.
