I just tried to update my AIO installation but it failed totally.
Installing collected packages: voluptuous, requests, async-timeout, astral, homeassistant, multidict, yarl
Found existing installation: voluptuous 0.9.3
Uninstalling voluptuous-0.9.3:
Exception:
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/shutil.py", line 522, in move
os.rename(src, real_dst)
PermissionError: [Errno 13] Permission denied: '/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/voluptuous-0.9.3.dist-info/DESCRIPTION.rst' -> '/tmp/pip-aw3ywtdf-uninstall/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/voluptuous-0.9.3.dist-info/DESCRIPTION.rst'
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/basecommand.py", line 215, in main
status = self.run(options, args)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/commands/install.py", line 342, in run
prefix=options.prefix_path,
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/req/req_set.py", line 778, in install
requirement.uninstall(auto_confirm=True)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/req/req_install.py", line 754, in uninstall
paths_to_remove.remove(auto_confirm)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/req/req_uninstall.py", line 115, in remove
renames(path, new_path)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/utils/__init__.py", line 267, in renames
shutil.move(old, new)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/shutil.py", line 535, in move
os.unlink(src)
