Upgrade from 103.4 to 105.2 fail
What shall I do with this issue?
Testing configuration at /tmp/config
INFO:homeassistant.util.package:Attempting install of hass-nabucasa==0.31
INFO:homeassistant.util.package:Attempting install of defusedxml==0.6.0
INFO:homeassistant.util.package:Attempting install of netdisco==2.6.0
INFO:homeassistant.util.package:Attempting install of PyNaCl==1.3.0
INFO:homeassistant.util.package:Attempting install of home-assistant-frontend==20200130.2
INFO:homeassistant.util.package:Attempting install of distro==1.4.0
INFO:homeassistant.util.package:Attempting install of aiohttp_cors==0.7.0
INFO:homeassistant.util.package:Attempting install of HAP-python==2.7.0
INFO:homeassistant.util.package:Attempting install of sqlalchemy==1.3.13
INFO:homeassistant.util.package:Attempting install of aioharmony==0.1.13
INFO:homeassistant.util.package:Attempting install of aiofiles==0.4.0
INFO:homeassistant.util.package:Attempting install of aiogithubapi==0.4.3
INFO:homeassistant.util.package:Attempting install of hacs_frontend==20200104192235
INFO:homeassistant.util.package:Attempting install of integrationhelper==0.2.2
INFO:homeassistant.util.package:Attempting install of semantic_version==2.8.4
INFO:homeassistant.util.package:Attempting install of fritzhome==1.0.4
INFO:homeassistant.util.package:Attempting install of pyatmo==3.2.2
ERROR:homeassistant.scripts.check_config:BURB
  File "/usr/local/lib/python3.7/site-packages/homeassistant/scripts/check_config.py", line 204, in check
    async_check_ha_config_file(hass)
  File "/usr/local/lib/python3.7/asyncio/base_events.py", line 579, in run_until_complete
    return future.result()
  File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/check_config.py", line 129, in async_check_ha_config_file
    config = config_schema(config)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 272, in __call__
    return self._compiled([], data)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
    return base_validate(path, iteritems(data), out)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 386, in validate_mapping
    cval = cvalue(key_path, value)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
    return schema(data)
  File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 373, in validate_mapping
    new_key = ckey(key_path, key)
    return schema(data)
  File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/config_validation.py", line 659, in validator
    value = config[key]
TypeError: string indices must be integers
Fatal error while loading config: string indices must be integers
Failed config
  General Errors:
    - string indices must be integers
Successful config (partial)
check the release notes breaking changes section.
https://www.home-assistant.io/blog/2020/02/05/release-105/#read-more
In my case I got this error because i did not change the netatmo configuration (in the file configuration.yaml) which is required to be changed when updating to 0.105.
Hope this helps
Yes I saw this, but I did not expect that to be changed before the update.
Ok, I try it and start a new test, thanks
TypeError: means that you are trying to perform an operation on a value whose type is not compatible with that operation. An Iterable is a collection of elements that can be accessed sequentially . In Python, iterable objects are indexed using numbers . When you try to access an iterable object using a string or a float as the index, an error will be returned as TypeError: string indices must be integers. This means that when you’re accessing an iterable object like a string or float value, you must do it using an integer value.
For example, str[hello"] and str[2.1] as indexes. As these are not integers, a TypeError exception is raised. This means that when you’re accessing an iterable object like a string or float value, you must do it using an integer value . If you are accessing items from a dictionary , make sure that you are accessing the dictionary itself and not a key in the dictionary.
Python supports slice notation for any sequential data type like lists, strings , tuples, bytes, bytearrays, and ranges. When working with strings and slice notation, it can happen that a TypeError: string indices must be integers is raised, pointing out that the indices must be integers, even if they obviously are.
