Strange error !! image not found :
> 0-02-21 17:59:14 INFO (SyncWorker_14) [hassio.docker.addon] Start Docker add-on hassioaddons/influxdb-amd64 with version 3.5.1
> 20-02-21 17:59:14 INFO (SyncWorker_4) [hassio.docker.addon] Start Docker add-on homeassistant/amd64-addon-ssh with version 8.4
> 20-02-21 17:59:14 INFO (SyncWorker_13) [hassio.docker.addon] Start Docker add-on hassioaddons/vscode-amd64 with version 2.0.0
> 20-02-21 17:59:15 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_influxdb
> 20-02-21 17:59:15 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_vscode
> 20-02-21 17:59:16 INFO (MainThread) [hassio.api.security] /dns/info access from a0d7b954_influxdb
> 20-02-21 17:59:19 INFO (SyncWorker_9) [hassio.docker.interface] Start homeassistant/qemux86-64-homeassistant
> 20-02-21 17:59:40 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
> 20-02-21 17:59:40 INFO (MainThread) [hassio.addons] Phase 'application' start 1 add-ons
> 20-02-21 17:59:41 INFO (SyncWorker_2) [hassio.docker.addon] Start Docker add-on homeassistant/amd64-addon-configurator with version 4.6
> 20-02-21 17:59:46 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
> 20-02-21 17:59:46 INFO (MainThread) [hassio.core] Hass.io is up and running
> 20-02-21 18:00:48 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.105.5
> 20-02-21 18:00:48 INFO (SyncWorker_7) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.105.3 to homeassistant/qemux86-64-homeassistant:0.105.5
> 20-02-21 18:00:48 INFO (SyncWorker_7) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.105.5.
> 20-02-21 18:02:39 ERROR (SyncWorker_7) [hassio.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:0.105.5 -> 404 Client Error: Not Found ("no such image: homeassistant/qemux86-64-homeassistant:0.105.5: No such image: homeassistant/qemux86-64-homeassistant:0.105.5").
> 20-02-21 18:02:39 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
