Upgrade from 2026.3.4 to 2026.4 endup with "Unable to connect to Home Assistant."
Hi everybody,
I’m upgrading HA to 2026.4, on my nuc,
I can log on, but get the windows
ha core check give me
[core-ssh config]$ ha core check
Processing… Done.
Command completed successfully.
ha core log
2026-04-03 17:16:28.293 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140714089926304] from 192.168.0.77 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/146.0.0.0 Safari/537.36): Unexpected error inside websocket API
File “/usr/src/homeassistant/homeassistant/components/websocket_api/http.py”, line 352, in async_handle
connection = await self._async_handle_auth_phase(auth, send_bytes_text)
File “/usr/src/homeassistant/homeassistant/components/websocket_api/http.py”, line 392, in _async_handle_auth_phase
if is_supervisor_unix_socket_request(request):
File “/usr/src/homeassistant/homeassistant/components/http/const.py”, line 20, in is_supervisor_unix_socket_request
supervisor_path := http.supervisor_unix_socket_path
AttributeError: ‘HomeAssistantHTTP’ object has no attribute ‘supervisor_unix_socket_path’
Same here. After a core update, core/os/supervisor update says everything is up-to-date: core is in 2026.4.1 but the 2026.4.1 update does not fix this issue apparently.
So I rolled back to 2026.3.4 with:
ha core update --version 2026.3.4
and login works again. Will be waiting for a fix.
Hi, same happened to me. 2026.4 and 2026.4.1 both cause the issue.
Try leaving it another day or so, and check the nuc welcome screen and logs for errors. Sometimes it can take a long time to update, it needs a reset to reconfigure, and people panic early.
For me it’s been like that for about half a day before I realized what happened, as the automations and notifications kept working. The only error was the above mentioned one. Tried multiple reboots as well. I’ve been using HA for years and nothing like this ever happened before
Same here: Hardware Intel NUC:
ha core info,
arch: amd64
machine: generic-x86-64
port: 8123
ssl: false
update_available: true
version: 2026.3.4
version_latest: 2026.4.1
watchdog: true
ha core check
Processing… Done.
ha os info
board: generic-x86-64
state: booted
status: good
version: “17.1”
update_available: false
version: “17.1”
version_latest: “17.1”
reboot did not help. HA installation stuck on 2026.3.4 !
Has anyone created an issue for this?
I haven’t open an issue and for me its not needed any more.
I try this again after 5h waiting time and now its working.
Maybe the docker download wasn’t available in the time of my first trys.
Now superviso logs show:
2026-04-07 22:11:55.858 INFO (MainThread) [supervisor.docker.interface] Downloading docker image Package generic-x86-64-homeassistant · GitHub with tag 2026.4.1.
Well, more than 24 hours have passed. I have retried os/core/supervisor updates. Os is 17.2, core is 2026.4.1 and supervisor is 2026.03.3 and I still get the same error and no login. Going back to 2026.3.4 solves it…
Bypasses, not solves.
As @petro advises, possibly raise a report in GitHub where the developers can action it.
Agreed, bypassed, not solved (not a native English speaker here :slight_smile:
I left a GitHub issue:
Can those in this thread affected by this issue check their custom_components directory for me? Multiple reporters in the referenced github issue turned out to have an http folder in there.
For those unaware, this directory is how extra community built integrations (such as from HACS) get incorporated into Home Assistant. However it also has another trick it can do. If the folder name you use in here matches a native integration such as http then it uses the code in that folder instead of the native code for that integration. Which means if you have a folder called http in your custom_components folder then you are not using the shipped code at all, you’re using a custom version of the http integration.
Well mostly. The http integration is obviously very core to the functionality of Home Assistant. So we believe what’s happening is to the users in the github issue is some code is being imported from the native http integration before the custom component is loaded. And this code references the new supervisor_unix_socket_path attribute that doesn’t exist in the custom overrides of HomeAssistantHTTP that get loaded later.
If this describes your setup I’d strongly recommend removing that custom component. The http integration is updated frequently and many many other integrations depend on it. A custom version is likely to be a constant source of catastrophic failures from release to release.
We would be curious to learn why you felt a need to do that though if you care to share. To see what we can improve in the core product to make that unnecessary going forward.
If I remember well, I installed it because it allowed to ban full subnetworks from the configuration.yaml file.
And I see it has been updated to work with 2026.4.1.
See Ban by subnet in http component (with working code)
If this was all caused by my http component I’m sorry but I didn’t see this thread and I don’t get advanced notice of HA code which breaks my component
Maybe in future raise problems with an issue on Github where the code now resides - I might see it quicker.
FWIW I’ve been informed by HA developers this subnet banning is never going to get into the core
Dude right above me made a PR to have this extremely useful feature merged in a year ago. He gets strung along for 6 months, only to be told no because “Giving users control over IP ranges to ban is not functionality we want to include in Home Assistant Core”.
Might be time to revisit that decision instead of having users resort to custom components or additional firewall addons.
:upside_down_face: Sometimes I feel a bit bad for contributors who don’t receive a clear explanation when their PR gets rejected.
It seems like this is becoming more common across both core and frontend repositories, and it can be discouraging, especially for people who are trying to help or improve things.
For some contributors, that PR might have been their last attempt to contribute, which is a bit unfortunate…
Mike, you find the solution, I removed the http folder from custom_components, restart my HA to check , and then the update went well.
Many thx
Hm that’s fair. I’ll ask although there are suggested alternatives in this comment that don’t involve replacing the http component with a custom one. For you and any others in here. Curious if those worked for people, had issues, or weren’t tried.
I did indeed read that comment, which is why I said
Someone saying “not user configurable (except for enabling or disabling the automatic banning)” in that comment sounds a bit off, considering affected users can manually enter individual IPs in that file
