I upgraded the OS to 7.0 and lost Zigbee2MTT integration. From the logs it looks my zha USB stick can no longer be accessed. HA is running on an ODROID N2 box.
Zigbee2MQTT:error 2021-12-11 16:02:23: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-12-11 16:02:23: Failed to start zigbee
Zigbee2MQTT:error 2021-12-11 16:02:23: Exiting...
Zigbee2MQTT:error 2021-12-11 16:02:23: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.<anonymous> (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31)
at Generator.throw (<anonymous>)
at rejected (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
It looks like both my USB connected devices are no longer accessible as I also have this error on a serial device:
2021-12-11 16:13:25 ERROR (MainThread) [custom_components.nuvo_serial] Error connecting to Nuvo controller at /dev/ttyUSB0
Any ideas - I see on github there is an issue logged with a WiFi dongle also linked to OS 7
Any ideas what I can look at next or should I just wait for a fix if this is a more general issue. I still see USB devices when I check the hardware
ttyUSB0
/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
ttyUSB1
/dev/serial/by-id/usb-Prolific_Technology_Inc._USB-Serial_Controller_D-if00-port0
Many thanks,
Tom
