how to resolve this?
nobody experience this issue?
ERROR: After October 2020 you may experience errors when installing or updating packages. This is because pip will change the way that it resolves dependency conflicts.
We recommend you use --use-feature=2020-resolver to test your packages with the new resolver before it becomes the default.
python-jose-cryptodome 1.3.2 requires pycryptodome<3.4.0,>=3.3.1, which is not installed.
pychromecast 6.0.0 requires zeroconf>=0.25.1, which is not installed.
netdisco 2.6.0 requires zeroconf>=0.21.0, which is not installed.
hap-python 2.8.4 requires zeroconf, which is not installed.
aiohomekit 0.2.29.2 requires zeroconf[ip]<0.25.0,>=0.24.4, which is not installed.
hass-nabucasa 0.34.2 requires pytz~=2019.3, but you'll have pytz 2020.1 which is incompatible.
