Hi all,
I have tried to upgrade to the latest build tonight as per the getting started info but I am getting an error each time and not sure what it means please could anyone shed some light on this.
Exception:
File "/usr/lib/python3.4/shutil.py", line 522, in move
os.rename(src, real_dst)
PermissionError: [Errno 13] Permission denied: '/usr/lib/python3/dist-packages/requests' -> '/tmp/pip-unzsvu96-uninstall/usr/lib/python3/dist-packages/requests'
File "/usr/local/lib/python3.4/dist-packages/pip/basecommand.py", line 215, in main
status = self.run(options, args)
File "/usr/local/lib/python3.4/dist-packages/pip/commands/install.py", line 317, in run
prefix=options.prefix_path,
File "/usr/local/lib/python3.4/dist-packages/pip/req/req_set.py", line 736, in install
requirement.uninstall(auto_confirm=True)
File "/usr/local/lib/python3.4/dist-packages/pip/req/req_install.py", line 742, in uninstall
paths_to_remove.remove(auto_confirm)
File "/usr/local/lib/python3.4/dist-packages/pip/req/req_uninstall.py", line 115, in remove
renames(path, new_path)
File "/usr/local/lib/python3.4/dist-packages/pip/utils/__init__.py", line 267, in renames
shutil.move(old, new)
File "/usr/lib/python3.4/shutil.py", line 532, in move
rmtree(src)
File "/usr/lib/python3.4/shutil.py", line 463, in rmtree
_rmtree_safe_fd(fd, path, onerror)
File "/usr/lib/python3.4/shutil.py", line 421, in _rmtree_safe_fd
onerror(os.unlink, fullname, sys.exc_info())
File "/usr/lib/python3.4/shutil.py", line 419, in _rmtree_safe_fd
os.unlink(name, dir_fd=topfd)
PermissionError: [Errno 13] Permission denied: '__init__.py'
Thanks again
Mike
