Upgrade keeps failing from 0.104.3 to 0.105.5
Hello
I am currently in 0.104.3 and trying to update to 0.105.5. But the upgrade keeps failing with this error.
20-02-19 02:04:04 ERROR (SyncWorker_17) [hassio.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.105.5 -> 404 Client Error: Not Found (“no such image: homeassistant/qemux86-64-homeassistant:0.105.5: No such image: homeassistant/qemux86-64-homeassistant:0.105.5”).
I do not have Netatmo like issues are pointing to.
What would be the best way to update without having to redo everything.
No space on disk?
There is enough space in the device.
And Hass can see/use it?
I presume you reboot and try upgrade again?
