System’s been working great the last couple of days, but this morning I woke up to all kinds of duplicate entries being created in known_devices.yaml. I started to edit it and then thought, “Eh, I’ll just back up the .yaml file, delete the original, check for an update to HA, and let it rebuild the file.” Evidently that was a big mistake. When I came back to check on the progress of the upgrade, the cmd window was a sea of red text and now my installation is hosed.
Heartbreak begins after “Successfully uninstalled homeassistant-0.43.2.”
HALP.
C:\Users\Network Closet>
C:\Users\Network Closet>pip3 install --upgrade homeassistant
Collecting homeassistant
Downloading homeassistant-0.44.0-py2.py3-none-any.whl (7.0MB)
100% |ââââââââââââââââââââââââââââââââ| 7.0MB 73kB/s
Requirement already up-to-date: async-timeout==1.2.0 in c:\users\network closet\
appdata\local\programs\python\python36-32\lib\site-packages (from homeassistant)
Requirement already up-to-date: pytz>=2017.02 in c:\users\network closet\appdata
Requirement already up-to-date: aiohttp==2.0.7 in c:\users\network closet\appdat
Requirement already up-to-date: pyyaml<4,>=3.11 in c:\users\network closet\appda
Requirement already up-to-date: chardet==3.0.2 in c:\users\network closet\appdat
Requirement already up-to-date: pip>=7.1.0 in c:\users\network closet\appdata\lo
Requirement already up-to-date: requests<3,>=2 in c:\users\network closet\appdat
Collecting voluptuous==0.10.5 (from homeassistant)
Downloading voluptuous-0.10.5.tar.gz (41kB)
100% |ââââââââââââââââââââââââââââââââ| 51kB 1.1MB/s
Requirement already up-to-date: typing<4,>=3 in c:\users\network closet\appdata\
Requirement already up-to-date: jinja2>=2.9.5 in c:\users\network closet\appdata
Requirement already up-to-date: multidict>=2.1.4 in c:\users\network closet\appd
ata\local\programs\python\python36-32\lib\site-packages (from aiohttp==2.0.7->ho
meassistant)
Collecting yarl<0.11,>=0.10.0 (from aiohttp==2.0.7->homeassistant)
Downloading yarl-0.10.1-cp36-cp36m-win32.whl (78kB)
100% |ââââââââââââââââââââââââââââââââ| 81kB 1.4MB/s
Requirement already up-to-date: MarkupSafe>=0.23 in c:\users\network closet\appd
ata\local\programs\python\python36-32\lib\site-packages (from jinja2>=2.9.5->hom
eassistant)
Installing collected packages: voluptuous, homeassistant, yarl
Found existing installation: voluptuous 0.9.3
Uninstalling voluptuous-0.9.3:
Successfully uninstalled voluptuous-0.9.3
Running setup.py install for voluptuous ... done
Found existing installation: homeassistant 0.43.2
Uninstalling homeassistant-0.43.2:
Exception:
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\sh
util.py", line 387, in _rmtree_unsafe
os.unlink(fullname)
PermissionError: [WinError 5] Access is denied: 'C:\\Users\\NETWOR~1\\AppData\\L
ocal\\Temp\\pip-c81wz1gv-uninstall\\users\\network closet\\appdata\\local\\progr
ams\\python\\python36-32\\scripts\\hass.exe'
File "c:\users\network closet\appdata\local\programs\python\python36-32\lib\si
te-packages\pip\basecommand.py", line 215, in main
status = self.run(options, args)
te-packages\pip\commands\install.py", line 342, in run
prefix=options.prefix_path,
te-packages\pip\req\req_set.py", line 795, in install
requirement.commit_uninstall()
te-packages\pip\req\req_install.py", line 767, in commit_uninstall
self.uninstalled.commit()
te-packages\pip\req\req_uninstall.py", line 142, in commit
rmtree(self.save_dir)
te-packages\pip\_vendor\retrying.py", line 49, in wrapped_f
return Retrying(*dargs, **dkw).call(f, *args, **kw)
te-packages\pip\_vendor\retrying.py", line 212, in call
raise attempt.get()
te-packages\pip\_vendor\retrying.py", line 247, in get
six.reraise(self.value[0], self.value[1], self.value[2])
te-packages\pip\_vendor\six.py", line 686, in reraise
raise value
te-packages\pip\_vendor\retrying.py", line 200, in call
attempt = Attempt(fn(*args, **kwargs), attempt_number, False)
te-packages\pip\utils\__init__.py", line 102, in rmtree
onerror=rmtree_errorhandler)
util.py", line 494, in rmtree
return _rmtree_unsafe(path, onerror)
util.py", line 384, in _rmtree_unsafe
_rmtree_unsafe(fullname, onerror)
[Previous line repeated 4 more times]
util.py", line 389, in _rmtree_unsafe
onerror(os.unlink, fullname, sys.exc_info())
te-packages\pip\utils\__init__.py", line 114, in rmtree_errorhandler
func(path)
