Have upgrade paths IE you cannot go from 2022.09.01 to 2022.10.3 without going to the last version of the release you are currently on. IE 2022.09.05 can upgrade to anything with in the 2022.10.* upgrade path. But 2022.09.4 must upgrade to 2022.09.5 before HA will allow you to upgrade to the latest release 2022.10.1. This would allow for smoother transition between versions and allow people to gradually catchup with breaking changes than just have to code them all in one hit. It would also allow home assistant to gradually upgrade it’s features in a more stable path than just to attempt it in one hit.
No thanks…
We are all adults, we should be able to take responsibility for our actions.
And I’m not sure this would make anyone more interested in reading the release notes just because they are forced to do 10 upgrades instead of one.
I still believe it’s better to display only the breaking changes that is related your install when you want to upgrade.
Is this a question or a feature request?
You can easily perform any upgrade (or downgrade) path you want using the command line.
ha core update --version x.y.z
ps: moved to Feature Requests.
