Upgrade problem
I am running home assistant using the Hyper-V pre-configured image.
It is working great, but I cant get it to upgrade in the UI.
I am running 112.2 and it tells me there is 112.4. It fails to update, but the log is empty.
Which upgrade process could I use from the command line
Is the hyper-v image running a dockerized container?
Any advice welcome
If you use the downloaded image as it is, there is not enough space. The download image has only 6 Gb allocated, expand it to at least 32 Gb.
Perfect, this fixed the issue thanks!
