I upgraded from 0.99.3 to 0.100.3 last night at 10:23pm. At that same time my Life360 tracker for my wife and I went to “not_home” although we were at home. I also had this in my log at the same time.
2019-10-21 23:38:20 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for life360 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-10-21 23:38:20 ERROR (MainThread) [homeassistant.config] Platform error: device_tracker
File "/usr/src/homeassistant/homeassistant/config.py", line 778, in async_process_component_config
platform = p_integration.get_platform(domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 232, in get_platform
f"{self.pkg_path}.{platform_name}"
File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/config/custom_components/life360/device_tracker.py", line 36, in <module>
from homeassistant.util.async_ import (
Here is my configuration.yaml
- platform: life360
username: [email protected]
password: XXXXXXXXX
prefix: life360
add_zones: all
show_as_state: places, moving
interval_seconds: 6
max_update_wait:
minutes: 30
Any idea how to fix this?
