Upgraded to 0.48.1 and system will not come up.
I can ssh into it fine but Ha does not load.
Getting this message in the home-assistant.log
2017-07-05 14:36:36 ERROR (MainThread) [homeassistant.bootstrap] Error loading $
Checked and both files are there.
Any help would be great.
tung256
(tung)
July 6, 2017, 2:29am
2
me too.
i tried http://192.168.1.202:8123
i can ssh into ip 202 fine. but the HA webpage wont load with that link i shared above. did the port changed?
After you perform an upgrade it can take a further 15 to 20 minutes for background updates to finish.
tung256
(tung)
July 6, 2017, 2:39am
4
you are right! back in business now…
It’s been hours and still no webpage.
hassbian.local:8123 or IP address nothing for either.
turboc
(Chip Cox)
July 6, 2017, 3:02am
6
check your log file for any dependencies that didn’t get loaded. Under linux I typically do the following.
ps -ef | grep -i depend
That will give me a list of dependencies that HA couldn’t load. Then I install the manually with pip3. That usually fixes things for me. What environment are you running under?
I would ssh into HA and see if it is running.
ps -ef | grep hass
If hass is running then tail home-assistant.log
You can also grep home-assistant /var/log/syslog
Grep for error, has ???
m4tek
(M4tek)
July 9, 2017, 6:56pm
8
I have same situation, hass is stale, running, but nothing is happening, log just frozen on:
Jul 09 18:47:14 xxxxxxxx hass[4049]: INFO:homeassistant.config:Upgrading config directory from 0.47.1 to 0.48.1
Jul 09 18:47:14 xxxxxxxx hass[4049]: Config directory: /home/ha/.homeassistant
m4tek
(M4tek)
July 9, 2017, 7:05pm
9
