Thanks @tmjpugh - it was the authentication providers piece that was killing it.
In the end I SSH’ed in to HassOS, caught the logs whilst it was trying to start 0.90 and saw the errors there. Fixed the config file for api_password and trusted_networks and then was able to complete an upgrade.
@anon34565116 - It seems to take a day or so for releases to filter through to hassOS. I’ve just upgraded to 0.90.1 now.
Thank you for the tip! I ended up troubleshooting using the ssh Hass.io add-on I set up awhile back.
For anyone else who finds this thread, I fixed things by commenting out the api_password entry in the http section, upgrading, then moving the api_password config to the auth_providers section: https://www.home-assistant.io/docs/authentication/providers/#legacy-api-password. NOTE: I was able to safely comment out the api_password – before doing so make sure you won’t lock yourself out of HA!
Also, after the failed upgrade from 0.89.x, all of my automations were turned off…had to go through and turn them back on.
I am having the same issues and tried to do upgrade from SSH which is said “ok” at then end and nothing. I am still sitting at 89. What did you configure in the config to make it work?
Noob question: how/where do I find the logs when SSH’ed to Hassio?
I am trying to upgrade from 0.89 to 0.92 without luck.
Will try the api_password later today.
