Upgrade to 0.95.4 failed (from 0.95.3) - SOLVED
When trying to upgrade (e.g. by doing:| hassio ha update --version 0.95.4)
I get if I analyse the error with (hassio supervisor logs):
19-07-11 15:11:51 ERROR (SyncWorker_6) [hassio.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.95.4 -> 404 Client Error: Not Found (“no such image: homeassistant/qemux86-64-homeassistant:0.95.4: No such image: homeassistant/qemux86-64-homeassistant:0.95.4”).
Any idea how to fix it?
Check your disk/sd card for free space. Should be minimum 1.3GB for update, i think.
I am using a qco2 image on proxmox and had allocated 36GB, turns out it wasn’t using the space… thnx for the tip @VDRainer!
