After my upgrade to 0.96, my docker container logs are much more limited (docker logs -f ha) shows a bit about start up and setting up components, but then logs end with this entry and then I never see anything else after this:
19-07-20 02:37:50 INFO (MainThread) [homeassistant.components.image_processing] Setting up image_processing.tensorflow
2019-07-20 02:37:50 INFO (SyncWorker_17) [homeassistant.loader] Loaded homekit_controller from homeassistant.components.homekit_controller
Any idea? I do have logger enabled, with level set to “INFO”. Home assistant itself is working fine a short while after that last log entry, so it is running and everything seems to be working fine.
