Need some help with an upgrade issue. I have a Centralite Pearl thermostat connected to HA via a conbee ii usb stick. I’ve been running 2021.3.4 for months, had no issues. The other day, I upgraded to 2021.6.6. Everything seemed fine, but my thermostat is no longer talking to HA.
“Reconfigure Device” button immediately fails. There is one warning in the logs:
I got this working again: I had to have the thermostat leave the network, delete and re-join. The new entity ID changed, so I had to update some automation. But all seems good again.
Turns out this problem happens when home assistant is restarted. I upgraded to 2017.4.4 and still had to leave + join. I tried the thermostat’s rejoin network function, but it didn’t seem to do anything.
This is a bummer, since it requires physical access to the thermostat.
Do you have this added with deCONZ, ZHA or Zigbee2MQTT? I just ordered two for my system and with my Conbee II and deCONZ, there is no battery and no cool mode, only heat and off. Can’t see heat/off mode from HA but can set temperature. Built a test server with ZHA and CC2531 dongle and everything works expect the battery level.
