Upgrade to 2023.6 failure on Synology Supervised Install
I have a Docker installation on Synology NAS running DSM 6. I tried to upgrade to 2023.6, however, the homeassistant/qemux86-64-homeassistant container will not now start.
Error message from Docker log says
Start container homeassistant failed: {“message”:“path /volume1/homeAssistant/hass.io/media is mounted on /volume1 but it is not a shared or slave mount”}.
This directory does exist, with no content. It was created back in January 2023.
Do I need to make a change to this directory, or permissions for the new version?
Any ideas welcome!
yes,me too.
it’s not now start.
I found a solution
The solution posted by @jyz0501 is only temporary. If Synology is restarted, the same problem occurs again. Is there a permanent fix?
For me this happened due to the Synology DSM 7.2 upgrade.
It was working fine with DSM 7.1 and HA 2023.6.2
Did you find a permanent fix @badshot?
You can make one scheduled script to do it every time the synology server is rebooted.
I have similar problem with the drivers of Sonoff Zigbee.
Create one Triggered Task from Control Panel. Select user root and “On boot” and paste the commands.
