in these captures, there used by % or secs or kb/s etc on each unit, all missing now after upgrade
also no state history graphs load any longer
strangely the weather card works, but the generic cards for the same data don’t show units anymore
Is it just the way the card is rendering the data? What do you see if you view some of these entities in /developer-tools/state? Do your logs having anything specific to report?
as i never looked at this before the update happened today, i’m not sure if this is what showed here in developer tools
nothing jumps out at me in the logs
Instead of clicking the entity itself, what you you see if you click the " i " icon next to the entity display name?
Did you already say you don’t see any history data?
Did you find anything in the system logs indicating problems with any of the sub-systems during startup?
NIck
Maybe try creating another dashboard & adding a couple of these entities there to see if they display differently for some reason.
i looked at the logs, first time so not really sure what to look for, didn’t see anything that hints of this problem
It seems clearly a bug introduced with the 2024.6 release. After I updated HA to this version I also can not see the history as shared by James. It seems that the Unit of Measurement is missing in the card.
I do see this UoM in version 2024.5.5 which I run on an other server.
it’s all fixed now… i didn’t do anything…
Good to hear! Still odd though…
I have the same issue after installing the core_2024.6.0. I was running core_2024.5.5 prior to updating to 2024.6.0. Unfortunately, it has not fixed itself. I tried a reboot to no avail.
All entity units do not display at all. All entity states show the default “off/on” instead of the specified states. The logs show nothing to indicate an issue.
I tried refreshing the web page, and it all loaded correctly. Problem solved.
Same problem here. A reload of the site did indeed solved the problem ![]()
I had this issue too, reload solved it, but it’s back and reload doesn’t solve it.
Clear browser buffer. Ctrl + F5
