Upgrade to Device Builder 2025.10.4 has lost my MSP2807 displays?
I can’t find any reference to this issue in the Change Logs. Anyone know whats happened?
If I want to attempt a Roll-Back, how is this done? I have a backup of 2025.10.3. Do I just Restore over the later version or do I need to Uninstall 2025.10.4 first then Restore?
Best regards, Martin
You have 2025.11.4 already ?
No need to uninstall, just restore.
Opps… Sorry finger trouble! Title corrected. Anyway…
With your advice, I was brave enough to roll-back to version 2025.8.x. And after a bit of chopping 'n changing, my problem seems to be related to framework AND Device Builder version.
  • framework: arduino / Builder: 2025.10 = Won’t compile (USBserial)
  • framework: esp-ide / Builder: 2025.10 = Compiles but display blank ([E][component:154]: display is marked FAILED)
  • framework: arduino / Builder: 2025.8 = Compiles & Displays :grinning:
  • framework: esp-ide / Builder: 2025.8 = Compiles but display blank
This is a (possibly relevent) section of the startup log:
[07:50:20][C][spi:075]:   Using HW SPI: SPI2_HOST
[07:50:20][C][ili9xxx:089]: ili9xxx
[07:50:20][C][ili9xxx:089]:   Rotations: 0 °
[07:50:20][C][ili9xxx:089]:   Dimensions: 240px x 320px
[07:50:20][C][ili9xxx:090]:   Width Offset: 0
[07:50:20][C][ili9xxx:090]:   Height Offset: 0
[07:50:20][C][ili9xxx:099]:   Color mode: 16bit
[07:50:20][C][ili9xxx:108]:   Data rate: 40MHz
[07:50:20][C][ili9xxx:110]:   Reset Pin: GPIO35
[07:50:20][C][ili9xxx:111]:   CS Pin: GPIO12
[07:50:20][C][ili9xxx:112]:   DC Pin: GPIO37
[07:50:20][C][ili9xxx:114]:   Color order: BGR
[07:50:20][C][ili9xxx:114]:   Swap_xy: NO
[07:50:20][C][ili9xxx:114]:   Mirror_x: YES
[07:50:20][C][ili9xxx:114]:   Mirror_y: NO
[07:50:20][C][ili9xxx:114]:   Invert colors: NO
[07:50:20][C][ili9xxx:124]:   => Failed to init Memory: YES!
[07:50:20][C][ili9xxx:126]:   Update Interval: 1.0s
[07:50:20][E][component:145]:   display is marked FAILED: unspecified
And this is the complete yaml:
esphome:
  friendly_name: "esp32s2 msp2807 Display"
esp32:
  board: lolin_s2_mini
  framework:
    #type: arduino
    type: esp-idf
# Enable logging
logger:
  level: DEBUG
  logs:
    component: ERROR # Suppress the "component took a long time" message!
    xpt2046: ERROR
    touchscreen: ERROR
# Enable Home Assistant API
api:
ota:
  - platform: esphome
    password: !secret ota_password
wifi:
  networks:
  #- ssid: !secret wifi_wa60hce
  #  password: !secret wifi_password
  - ssid: !secret wifi_ssid
web_server:
  port: 80
captive_portal:
font:
  - file: "fonts/DejaVuSans.ttf"
#For MSP2807 pinout/nomenclature see: ~/tft-msp2807/Docs/2.8inch_SPI_Module_MSP2807_User_Manual_EN.pdf
spi: #VSPI
 clk_pin:  GPIO7  #TFT_SCK (Pin 7) & T_CLK (Pin 10)
 miso_pin: GPIO9  #T_DOut   (Pin 13)
 mosi_pin: GPIO11 #TFT_MOSI (Pin 6) & T_DIN (Pin 12)
display:
  - platform: ili9xxx
    model: ili9341
    invert_colors: false
    cs_pin:    GPIO12 #TFT_CS (Pin 3)
    reset_pin: GPIO35 #TFT_RST (Pin 4)
    dc_pin:    GPIO37 #TFT_D/C (Pin 5)
    rotation: 0
    lambda: |-
      //Background Colour
      it.fill(Color::BLACK);
      it.printf(id(line1x), id(line1y), id(my_font), TextAlign::TOP_LEFT, "Temperature");
      it.printf(it.get_width(), id(line1y), id(my_font), TextAlign::TOP_RIGHT, " %.1f°C", id(outside_temp).state);
      //Seperator & waste colours
      auto red = Color(255, 0, 0);
      auto green = Color(0, 255, 0);
      it.filled_rectangle(20, 40, 200, 5, red);
      it.printf(id(line2x), id(line2y), id(my_font), "Veh.Volts");
      it.printf(it.get_width(), id(line2y), id(my_font), TextAlign::TOP_RIGHT, " %.1fV", id(veh_volts).state);
      it.printf(id(line3x), id(line3y), id(my_font), "Veh.Amps");
      it.printf(it.get_width(), id(line3y), id(my_font), TextAlign::TOP_RIGHT, " %.1fA", id(veh_amps).state);
      it.printf(id(line4x), id(line4y), id(my_font), "Lei.Volts");
      it.printf(it.get_width(), id(line4y), id(my_font), TextAlign::TOP_RIGHT, " %.1fV", id(lei_volts).state);
      it.printf(id(line5x), id(line5y), id(my_font), "Lei.Amps");
      it.printf(it.get_width(), id(line5y), id(my_font), TextAlign::TOP_RIGHT, " %.1fA", id(lei_amps).state);
      it.filled_rectangle(20, 180, 200, 5, red);
      it.printf(id(line6x), id(line6y), id(my_font), "Mobo Bal.");
      it.printf(it.get_width(), id(line6y), id(my_font), TextAlign::TOP_RIGHT, " %.1fGB", id(mobo_balance).state);
      it.filled_rectangle(20, 220, 200, 5, red);
      it.printf(id(line7x), id(line7y), id(my_font), "LPG Level");
      it.printf(it.get_width(), id(line7y), id(my_font), TextAlign::TOP_RIGHT, " %.0f%%", id(lpg_level).state);
      it.filled_rectangle(20, 270, 200, 5, red);
      //it.printf(id(line8x), id(line8y), id(small_font),  Color(0xFFFF00), "IP Address:");
      //it.printf(it.get_width(), id(line8y), id(small_font), Color(0xFFFF00), TextAlign::TOP_RIGHT, "%s", id(my_ip_addrs).state.c_str() );
      it.printf(id(line8x), id(line8y), id(my_font), id(waste_valve).state ? Color(red) : Color(green), "Waste Valve");
      it.printf(it.get_width(), id(line8y), id(my_font), id(waste_valve).state ? Color(red) : Color(green), TextAlign::TOP_RIGHT, "%s", id(waste_valve).state ? "OPEN" : "CLOSED" );
#text_sensor:
#  - platform: wifi_info
#    ip_address:
#      id: my_ip_addrs
binary_sensor:
  - platform: homeassistant
    #entity_id: binary_sensor.esp32_s3_zero_waste
    entity_id: binary_sensor.motorhome_ds18b20_waste_temp_waste
    #on_state:
    #  then:
    #    - logger.log: "mpr says: waste value has changed"
    entity_id: sensor.motorhome_ds18b20_waste_temp_temperature
    entity_id: sensor.motorhome_hlsr10_bat_lei_voltage
    entity_id: sensor.motorhome_hlsr10_bat_lei_current
    entity_id: sensor.motorhome_hlsr10_bat_veh_voltage
    #on_value:
    #  then:
    #    - logger.log: "mpr says: veh volts has changed"
    entity_id: sensor.motorhome_hlsr10_bat_veh_current
    entity_id: sensor.mobo_balance
    #entity_id: sensor.esp32s2_as5600_position
    entity_id: sensor.motorhome_as5600_lpg_custom_raw_position
output:
  - platform: ledc
    pin: GPIO16 # TFT_BLIGHT (Pin8)
light:
  - platform: monochromatic
    output: backlight
    restore_mode: ALWAYS_ON
switch:
  - platform: restart
touchscreen:
  platform: xpt2046
  cs_pin: GPIO39 #T_CS (Pin11)
  update_interval: 50ms
  threshold: 400
  calibration:
    x_min: 280
    x_max: 3860
    y_min: 340
    y_max: 3860
  on_touch:
    - if:
        condition:
          - lambda: 'return id(backlightctl).current_values.get_brightness() == 0.5;'
        then:
          - light.dim_relative:
              relative_brightness: +50%
        else:
              relative_brightness: -50%
globals:
  - id: line1x
    type: int
    initial_value: '0'
  - id: line1y
    type: int
    initial_value: '0'
  - id: line2x
    type: int
    initial_value: '0'
  - id: line2y
    type: int
    initial_value: '50'
  - id: line3x
    type: int
    initial_value: '0'
  - id: line3y
    type: int
    #initial_value: '100'
    initial_value: id(line2y)+30
  - id: line4x
    type: int
    initial_value: '0'
  - id: line4y
    type: int
    #initial_value: '160'
    initial_value: id(line3y)+30
  - id: line5x
    type: int
    initial_value: '0'
  - id: line5y
    type: int
    #initial_value: '200'
    initial_value: id(line4y)+30
  - id: line6x
    type: int
    initial_value: '0'
  - id: line6y
    type: int
    initial_value: id(line5y)+50
  - id: line7x
    type: int
    initial_value: '0'
  - id: line7y
    type: int
    initial_value: id(line6y)+50
  - id: line8x
    type: int
    initial_value: '0'
  - id: line8y
    type: int
    initial_value: id(line7y)+50
