Hey,
Just did the upgrade to DSM 7
All went wel as for my HA which is running in VM
HA can not be reached anymore…
Some of you had the same problem and have a solution?
Hey,
What does VM manager in Synolog says - any strange info, any info missing (IP’s…)? Did you try to restart it?
In VM manager under “general” you should IP of HA installation written
Too late to advice already, but…did you shut down HA’s VM before upgrade or you just started to upgrade with running VM? One of options is, if VM was shut down wrong it can be corrupted.
tnx for the advice.
Was indeed missing my ip from de VM, after few restarts it seems back to normal
