Anyone else having to upgrade twice for HASS to work? My process (for at least the last 3-4 releases) has been as follow:
systemctl stop home-assistant@hass
su -s /bin/bash hass
virtualenv -p python3 /var/opt/home-assistant
source /var/opt/home-assistant/bin/activate
pip3 install --upgrade homeassistant
systemctl start home-assistant@hass
After the first upgrade when I start HASS fails to load/find the components:
Jun 20 09:56:20 automation systemd[1]: Started Home Assistant.
Jun 20 09:56:26 automation hass[8563]: INFO:homeassistant.bootstrap:Upgrading config directory from 0.21.2 to 0.22.1
Jun 20 09:56:27 automation hass[8563]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
Jun 20 09:56:27 automation hass[8563]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
Jun 20 09:56:27 automation hass[8563]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=toggle>
Jun 20 09:56:27 automation hass[8563]: INFO:homeassistant.bootstrap:Home Assistant core initialized
Jun 20 09:56:27 automation hass[8563]: ERROR:homeassistant.loader:Unable to find component input_boolean
Jun 20 09:56:27 automation hass[8563]: ERROR:homeassistant.loader:Unable to find component wemo
Jun 20 09:56:27 automation hass[8563]: ERROR:homeassistant.loader:Unable to find component wink
After going through the upgrade the process the 2nd time:
Jun 20 09:57:42 automation systemd[1]: Starting Home Assistant...
Jun 20 09:57:42 automation systemd[1]: Started Home Assistant.
Jun 20 09:57:48 automation hass[8638]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
Jun 20 09:57:48 automation hass[8638]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
Jun 20 09:57:48 automation hass[8638]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=toggle>
Jun 20 09:57:48 automation hass[8638]: INFO:homeassistant.bootstrap:Home Assistant core initialized
Jun 20 09:57:48 automation hass[8638]: INFO:homeassistant.loader:Loaded input_boolean from homeassistant.components.input_boolean
Jun 20 09:57:48 automation hass[8638]: INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
Jun 20 09:57:48 automation hass[8638]: INFO:homeassistant.loader:Loaded device_tracker from homeassistant.components.device_tracker
Jun 20 09:57:48 automation hass[8638]: INFO:homeassistant.loader:Loaded zone from homeassistant.components.zone
Jun 20 09:57:48 automation hass[8638]: INFO:homeassistant.loader:Loaded automation from homeassistant.components.automation
