Hi there,
I own a Zehnder Q450 device and installed the official plugin which shows quite nice sensors already. I read that the underlaying framework which is used is based on https://github.com/michaelarnauts/comfoconnect which is marked as deprecated and now replaced by https://github.com/michaelarnauts/aiocomfoconnect. The new library actually adds support for some features I am currently missing in the integration, namely:
Get the bypass mode (auto, on, off)
Set the bypass mode (auto, on, off)
Get the balance mode (balance / supply only / exhaust only)
Set the balance mode (balance / supply only / exhaust only)
Get the boost mode (on/off)
Set the boost mode (boolean)
Get the away mode (boolean)
Set the away mode (boolean)
Get the temperature profile.
Set the temperature profile. (warm / normal / cool)
It would be awesome to switch to the new library and add support for these features to be able to control the device even better.
I just found this integration which is basically what I asked for, would be nice to merge these two integrations into one and add the boost and away mode, then we have it.
Hi there, I set up HA the last weeks and got nearly all things in my house integrated. I also own a Zehnder Q450 and tried to install the repository via HACS. Unfortunately both quoted repositories seem not to be supported anymore. The old one …/comfoconnect ist not accepted (add button does not react), the other one …/aiocomfoconnect gets the error “<Integration michaelarnauts/aiocomfoconnect> Repository structure for v0.1.14 is not compliant”. Any idea what is wrong?
Best regards from Munich
Thomas
Thanks for this post I do own the q450 Connect-lan and like to integrate my home sensors like co2 and Location to automaten the home away function and reduce the m3 to what is needed.
