After some long overdue maintenance on my raspberry pi i upgraded to bullseye and updated all my packages. After upgrading home assistant i saw that i should be using the new ZwaveJS so i went through all the hoops to get that to run with home assistant on docker.
Now that it’s all set up it instantly recognized my QuickStick Combo HUSBZB-1, but its also showing three unknown device nodes…
I’m not sure how it sees three devices when my only zwave device is a schlage door lock. I wanted to set up an Innovelli Red today (which side tracked me into upgrading all this stuff) but before the upgrade the only device was the door lock.
Moreover, it seems to be stuck on the interview for all devices.
Is there a way to force remove all these devices so i can just try to enroll my door lock as new?
