16-05-26 15:19:42 homeassistant.components.device_tracker: Error setting up platform asuswrt
File “/home/hass/deps/pexpect/spawnbase.py”, line 144, in read_nonblocking
s = os.read(self.child_fd, size)
OSError: [Errno 5] Input/output error
File “/home/hass/deps/pexpect/expect.py”, line 97, in expect_loop
incoming = spawn.read_nonblocking(spawn.maxread, timeout)
File “/home/hass/deps/pexpect/pty_spawn.py”, line 455, in read_nonblocking
return super(spawn, self).read_nonblocking(size)
File “/home/hass/deps/pexpect/spawnbase.py”, line 149, in read_nonblocking
raise EOF(‘End Of File (EOF). Exception style platform.’)
pexpect.exceptions.EOF: End Of File (EOF). Exception style platform.
File “/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/device_tracker/init.py”, line 119, in setup_platform
scanner = platform.get_scanner(hass, {DOMAIN: p_config})
File “/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/device_tracker/asuswrt.py”, line 48, in get_scanner
scanner = AsusWrtDeviceScanner(config[DOMAIN])
File “/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/device_tracker/asuswrt.py”, line 68, in init
data = self.get_asuswrt_data()
File “/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/device_tracker/asuswrt.py”, line 153, in get_asuswrt_data
neighbors, leases_result = self.ssh_connection()
File “/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/device_tracker/asuswrt.py”, line 112, in ssh_connection
ssh.login(self.host, self.username, self.password)
File “/home/hass/deps/pexpect/pxssh.py”, line 280, in login
i = self.expect(["(?i)are you sure you want to continue connecting", original_prompt, “(?i)(?:password)|(?:passphrase for key)”, “(?i)permission denied”, “(?i)terminal type”, TIMEOUT, “(?i)connection closed by remote host”], timeout=login_timeout)
File “/home/hass/deps/pexpect/spawnbase.py”, line 315, in expect
timeout, searchwindowsize, async)
File “/home/hass/deps/pexpect/spawnbase.py”, line 339, in expect_list
return exp.expect_loop(timeout)
File “/home/hass/deps/pexpect/expect.py”, line 102, in expect_loop
return self.eof(e)
File “/home/hass/deps/pexpect/expect.py”, line 49, in eof
raise EOF(msg)
<pexpect.pxssh.pxssh object at 0x76484850>
command: /usr/bin/ssh
args: [’/usr/bin/ssh’, ‘-q’, ‘-l’, ‘admin’, ‘192.168.1.1’]
searcher: None
buffer (last 100 chars): b’’
before (last 100 chars): b’’
after: <class ‘pexpect.exceptions.EOF’>
match: None
match_index: None
exitstatus: None
flag_eof: True
pid: 873
child_fd: 7
closed: False
timeout: 30
delimiter: <class ‘pexpect.exceptions.EOF’>
logfile: None
logfile_read: None
logfile_send: None
maxread: 2000
ignorecase: False
searchwindowsize: None
delaybeforesend: 0.05
delayafterclose: 0.1
delayafterterminate: 0.1
16-05-26 15:19:44 homeassistant.components.recorder: Found unfinished sessions
Thanks in Advance,
Calvin
