I just did the upgrade from 0.24 to 0.24.1 on my RaspberryPi 2 with HASS and now I cannot start hass anymore. When trying to start manually, I am getting this as the error:
pi@homeassistant:~ $ hass
Config directory: /home/pi/.homeassistant
INFO:homeassistant.config:Upgrading config directory from 0.24.0 to 0.24.1
File "/usr/local/bin/hass", line 11, in
sys.exit(main())
File "/usr/local/lib/python3.4/dist-packages/homeassistant/__main__.py", line 327, in main
exit_code = setup_and_run_hass(config_dir, args)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/__main__.py", line 244, in setup_and_run_hass
log_rotate_days=args.log_rotate_days)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py", line 292, in from_config_file
skip_pip=skip_pip)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py", line 227, in from_config_dict
conf_util.process_ha_config_upgrade(hass)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/config.py", line 192, in process_ha_config_upgrade
shutil.rmtree(lib_path)
File "/usr/lib/python3.4/shutil.py", line 463, in rmtree
_rmtree_safe_fd(fd, path, onerror)
File "/usr/lib/python3.4/shutil.py", line 401, in _rmtree_safe_fd
_rmtree_safe_fd(dirfd, fullname, onerror)
File "/usr/lib/python3.4/shutil.py", line 421, in _rmtree_safe_fd
onerror(os.unlink, fullname, sys.exc_info())
File "/usr/lib/python3.4/shutil.py", line 419, in _rmtree_safe_fd
os.unlink(name, dir_fd=topfd)
OSError: [Errno 117] Structure needs cleaning: 'testtools.py'
Could anyone help?
