Upgraded to 0.62 - log file full
Is this normal? Was not there befor upgrading to 0.62
2018-01-28 20:35:58 WARNING (MainThread) [homeassistant.setup] Setup of xiaomi_aqara is taking over 10 seconds.
2018-01-28 20:36:00 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform cast is taking over 10 seconds.
2018-01-28 21:07:02 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.teknikskab_humidity is taking over 10 seconds
2018-01-28 22:31:28 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/lib/python3.5/asyncio/tasks.py”, line 241, in _step
result = coro.throw(exc)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/init.py”, line 332, in async_update_config
dev_id, device)
File “/usr/lib/python3.5/asyncio/futures.py”, line 380, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.5/asyncio/tasks.py”, line 304, in _wakeup
future.result()
File “/usr/lib/python3.5/asyncio/futures.py”, line 293, in result
raise self._exception
File “/usr/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/init.py”, line 751, in update_config
out.write(dump(device))
UnicodeEncodeError: ‘latin-1’ codec can’t encode character ‘\u017e’ in position 158: ordinal not in range(256)
2018-01-28 22:31:48 WARNING (Thread-2) [netdisco.ssdp] Found malformed XML at http://192.168.1.159:9080: status=ok
2018-01-28 22:41:19 WARNING (MainThread) [homeassistant.core] Unable to find service scene/turn_off
2018-01-28 22:41:19 WARNING (Thread-19) [pychromecast.controllers] STOP command requested but no session is active.
2018-01-29 02:08:05 WARNING (Thread-35) [pychromecast.socket_client] Heartbeat timeout, resetting connection
2018-01-29 02:08:21 ERROR (Thread-35) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-01-29 02:27:00 WARNING (Thread-33) [pychromecast.socket_client] Heartbeat timeout, resetting connection
2018-01-29 03:37:31 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 03:37:41 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 04:54:05 WARNING (Thread-34) [pychromecast.socket_client] Heartbeat timeout, resetting connection
2018-01-29 06:16:51 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:17:01 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:17:11 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:17:21 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:17:31 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:17:41 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:17:51 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:17:57 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:18:01 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:18:11 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:18:21 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:18:31 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:18:41 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:18:51 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:19:01 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:19:11 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:19:21 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:19:31 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:19:41 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:19:52 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:20:01 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:20:11 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:20:21 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:20:31 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:20:41 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:20:51 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:21:01 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:21:11 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:21:21 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:21:31 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:21:41 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:21:51 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:22:01 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:22:11 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:22:21 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:22:31 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:22:41 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:22:51 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:22:58 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:23:01 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:23:11 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:23:21 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:23:31 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:23:41 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:23:51 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:24:01 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:24:11 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:24:21 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:24:31 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:24:41 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:24:51 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:25:01 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:25:11 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:25:21 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:25:31 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:25:41 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:25:51 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:26:01 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:26:11 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:26:21 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:26:31 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:26:41 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:26:51 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:27:01 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:27:11 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:27:21 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:27:31 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:27:40 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:27:41 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:27:42 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:27:51 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:27:52 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:27:59 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:28:01 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:28:02 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:28:11 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:28:12 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:28:21 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:28:23 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:28:31 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:28:32 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:28:41 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:28:42 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:28:51 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:28:52 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:29:01 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:29:02 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:29:11 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:29:12 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29 06:29:21 WARNING (MainThread) [haffmpeg.tools] Timeout reading image.
2018-01-29
