Hi, I have upgraded to 0.88.2 from 83.X and all my devices are gone although the configuration.yaml file is still there. PLEASE HELP!!
Any error messages in the system log?
19-03-01 17:13:22 INFO (SyncWorker_5) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-ssh with version 5.1
19-03-01 17:13:22 WARNING (MainThread) [hassio.api.security] /addons/a0d7b954_ssh/info no role for a0d7b954_ssh
19-03-01 17:13:22 ERROR (MainThread) [hassio.api.security] Invalid token for access /addons/a0d7b954_ssh/info
19-03-01 17:13:23 WARNING (MainThread) [hassio.api.security] /addons/a0d7b954_ssh/info no role for a0d7b954_ssh
19-03-01 17:13:23 ERROR (MainThread) [hassio.api.security] Invalid token for access /addons/a0d7b954_ssh/info
19-03-01 17:13:23 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_ssh
19-03-01 17:13:24 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_ssh
19-03-01 17:13:25 WARNING (MainThread) [hassio.api.security] /addons/a0d7b954_ssh/info no role for a0d7b954_ssh
19-03-01 17:13:25 ERROR (MainThread) [hassio.api.security] Invalid token for access /addons/a0d7b954_ssh/info
19-03-01 17:13:25 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_ssh
19-03-01 17:13:29 INFO (SyncWorker_18) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.88.2
19-03-01 17:13:59 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-03-01 17:13:59 INFO (MainThread) [hassio.addons] Startup application run 2 add-ons
19-03-01 17:14:03 INFO (SyncWorker_3) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-configurator with version 2
19-03-01 17:14:04 INFO (SyncWorker_4) [hassio.docker.addon] Start Docker add-on hassioaddons/appdaemon3-armhf with version 1.1.0
19-03-01 17:14:06 WARNING (MainThread) [hassio.api.security] /addons/a0d7b954_appdaemon3/info no role for a0d7b954_appdaemon3
19-03-01 17:14:06 ERROR (MainThread) [hassio.api.security] Invalid token for access /addons/a0d7b954_appdaemon3/info
19-03-01 17:14:06 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_appdaemon3
19-03-01 17:14:07 WARNING (MainThread) [hassio.api.security] /addons/a0d7b954_appdaemon3/info no role for a0d7b954_appdaemon3
19-03-01 17:14:07 ERROR (MainThread) [hassio.api.security] Invalid token for access /addons/a0d7b954_appdaemon3/info
19-03-01 17:14:07 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_appdaemon3
19-03-01 17:14:09 WARNING (MainThread) [hassio.api.security] /addons/a0d7b954_appdaemon3/info no role for a0d7b954_appdaemon3
19-03-01 17:14:09 ERROR (MainThread) [hassio.api.security] Invalid token for access /addons/a0d7b954_appdaemon3/info
19-03-01 17:14:09 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-03-01 17:14:09 INFO (MainThread) [hassio.core] Hass.io is up and running
19-03-01 17:14:14 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services/persistent_notification/create access from core_configurator
19-03-01 17:14:14 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-03-01 17:16:59 INFO (SyncWorker_9) [hassio.docker.interface] Update Docker homeassistant/armhf-addon-mosquitto:1.0 to homeassistant/armhf-addon-mosquitto:4
19-03-01 17:16:59 INFO (SyncWorker_9) [hassio.docker.interface] Pull image homeassistant/armhf-addon-mosquitto tag 4.
19-03-01 17:17:48 INFO (SyncWorker_9) [hassio.docker.interface] Tag image homeassistant/armhf-addon-mosquitto with version 4 as latest
19-03-01 17:17:48 INFO (SyncWorker_9) [hassio.docker.interface] Stop homeassistant/armhf-addon-mosquitto Docker application
19-03-01 17:17:49 INFO (SyncWorker_9) [hassio.docker.interface] Clean homeassistant/armhf-addon-mosquitto Docker application
19-03-01 17:17:49 INFO (SyncWorker_9) [hassio.docker.interface] Cleanup Docker images: [‘homeassistant/armhf-addon-mosquitto:1.0’]
19-03-01 17:17:50 WARNING (MainThread) [hassio.addons.validate] Unknown options plain
19-03-01 17:17:50 WARNING (MainThread) [hassio.addons.validate] Unknown options ssl
19-03-01 17:17:53 INFO (SyncWorker_2) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-mosquitto with version 4
19-03-01 17:17:53 INFO (MainThread) [hassio.services.mqtt] Set core_mosquitto as service provider for mqtt
19-03-01 17:17:53 INFO (MainThread) [hassio.discovery] Send discovery to Home Assistant mqtt from core_mosquitto
19-03-01 17:17:53 INFO (MainThread) [hassio.discovery] Discovery 9f92d48be90c4e61b2a3aaf48352b562 message send
19-03-01 17:17:55 INFO (SyncWorker_16) [hassio.docker.interface] Stop homeassistant/armhf-addon-mosquitto Docker application
19-03-01 17:17:57 INFO (SyncWorker_16) [hassio.docker.interface] Clean homeassistant/armhf-addon-mosquitto Docker application
19-03-01 17:17:57 WARNING (MainThread) [hassio.addons.validate] Unknown options plain
19-03-01 17:17:57 WARNING (MainThread) [hassio.addons.validate] Unknown options ssl
19-03-01 17:17:59 INFO (SyncWorker_1) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-mosquitto with version 4
19-03-01 17:17:59 INFO (MainThread) [hassio.services.mqtt] Set core_mosquitto as service provider for mqtt
19-03-01 17:18:00 INFO (MainThread) [hassio.discovery] Duplicate discovery message from core_mosquitto
19-03-01 17:19:07 WARNING (MainThread) [hassio.addons.validate] Unknown options plain
19-03-01 17:19:07 WARNING (MainThread) [hassio.addons.validate] Unknown options ssl
19-03-01 17:19:53 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
19-03-01 17:19:53 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
19-03-01 17:19:53 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
19-03-01 17:20:22 INFO (SyncWorker_1) [hassio.docker.interface] Update Docker hassioaddons/appdaemon3-armhf:1.1.0 to hassioaddons/appdaemon3-armhf:1.7.0
19-03-01 17:20:22 INFO (SyncWorker_1) [hassio.docker.interface] Pull image hassioaddons/appdaemon3-armhf tag 1.7.0.
19-03-01 17:21:33 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
19-03-01 17:21:33 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
19-03-01 17:21:33 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
19-03-01 17:21:49 INFO (SyncWorker_1) [hassio.docker.interface] Tag image hassioaddons/appdaemon3-armhf with version 1.7.0 as latest
19-03-01 17:21:49 INFO (SyncWorker_1) [hassio.docker.interface] Stop hassioaddons/appdaemon3-armhf Docker application
19-03-01 17:21:50 INFO (SyncWorker_1) [hassio.docker.interface] Clean hassioaddons/appdaemon3-armhf Docker application
19-03-01 17:21:50 INFO (SyncWorker_1) [hassio.docker.interface] Cleanup Docker images: [‘hassioaddons/appdaemon3-armhf:1.1.0’]
19-03-01 17:21:55 INFO (SyncWorker_4) [hassio.docker.addon] Start Docker add-on hassioaddons/appdaemon3-armhf with version v1.7.0
19-03-01 17:21:59 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_appdaemon3
19-03-01 17:22:01 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_appdaemon3
19-03-01 17:22:03 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_appdaemon3
19-03-01 17:22:04 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_appdaemon3
19-03-01 17:22:04 INFO (MainThread) [hassio.api.security] /homeassistant/info access from a0d7b954_appdaemon3
19-03-01 17:22:05 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_appdaemon3
19-03-01 17:22:06 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_appdaemon3
19-03-01 17:23:21 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
19-03-01 17:23:21 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
19-03-01 17:23:21 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
19-03-01 17:28:38 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
19-03-01 17:28:38 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
19-03-01 17:28:38 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
19-03-01 17:38:21 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
19-03-01 17:38:21 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
19-03-01 17:38:21 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
19-03-01 17:42:28 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
19-03-01 17:42:28 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
19-03-01 17:42:28 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
19-03-01 17:48:28 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
19-03-01 17:48:28 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-03-01 17:48:28 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
19-03-01 17:48:28 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
I guess there are lots of them…
You have some configuration errors that were previously ignored. Try running the hass.io configuration check add-on if you are able.
Here are some of the errors I see. You can look for them in your configuration.
Fix those errors & restart Hass.io.
How do you use it?? I started it and it just says:
Log
[Info] Start install HomeAssistant latest
It takes a while to finish, sit back, relax and wait.
Wait for the task to finish and check the log again at the bottom of the page. Hit Refresh if needed.
It is checking your config against the latest version of Home Assistant. They recommend running the check before you upgrade.
Log
[Info] Start install HomeAssistant latest You are using pip version 18.0, however version 19.0.3 is available. You should consider upgrading via the ‘pip install --upgrade pip’ command. [Info] Install done, check config now [Info] Configuration check finished - no error found!
OK, I thought it was worth a try…
I guess you need to check your configuration.yaml for the words “ssl” & “plain” and make sure they are valid options in their entities.
http:
Secrets are defined in the file secrets.yaml
api_password: xxxxxxxxx
ip_ban_enabled: True
login_attempts_threshold: 5
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
base_url: xxx.axx.com:8123
I can only find SSL in the http: section
the Uncomment this if you are using SSL/TLS, running in Docker container, etc is commented.
Do I need to uncomment it?
Not if you are just using http, which is the default.
what next?
The errors look MQTT related to me.
I am new to Hassio too and have not used MQTT…
I agree, check your MQTT configuration. I have not used MQTT either, but I know there were some breaking changes introduced in a recent release.
