Upgraded to 2023.12.1. All my Solis (solar) sensors/entities have disappeared
SOLVED
I found elsewhere, in the sensor yaml, just remove any lines with “count”
In my case count :1 & count :2.
(Leave lazy_count, or I have)
HA on Synology NAS in a container
follow up : think something to do with ModBus - see bottom, will investigate but not sure what this is causing a problem, I don’t know enough about this…
Been working fine, just upgraded HA via container manager on the DS220, via image “upgrade” All seemed to work OK.
Not got a lot else on HA but few basic sensors, weather forecast, even local Tuya all OK.
But anything to do with my Solis Solar, (dozens of entities) says not available.
restarted HA, container, whole NAS etc etc.
The yaml files all seem to be there, main configuration files seem the same.
Been a while since I messed about with HA so not sure what I might be missing & takes a bit for my brain to get back into programming mode.
I access the NAs via Visual studio code & all seems fine.
What might have changed during this upgraded?
To be honest running some months & don’t remember upgrading before so not sure if likely to have ever encountered before
Not sure where my Solis.yaml is referred too, wondered if link to this is missing somewhere but the config & all the other yaml seem as before?
Home Assistant Core
Setup failed for ‘modbus’: Invalid config.
13:02:30 – (ERROR) setup.py
