Homeassistant won’t load and this is in the error file. Anyone else face this?
Thanks!
Thanks!
It’s in the release notes under the FAQ section, but it should print an error and continue, not prevent the system from starting. Are there any other errors in the log?
Add the elevation to your configuration.yaml file.
elevation: 50
Replace 50 with the number reported in the error.
Thanks! It auto fixed itself after a while. I didn’t notice the release notes. Appreciate the help folks.
do you guys know a good web to extract that information, Google maps is really good for Lat/Long but not for elevation.
Thanks!
The error message will have a good estimate. You can use that or go here:
