i plugged it into a monitor to see where it is at and it loads, but the web ui doesn’t show up
I can ping it and I can ssh into it, but thats it, i can’t even migrade to the shared drive anymore on my mac, even though that was enabled
Any thing in the home-assistant.log in the config directory?
is ther a way to check from ssh? the shared drive isn’t loading
yep if you ssh to the machine, my config directory for example is in /home/homeassistant/.homeassistant
It holds all the YAML files etc and if local the database. look for a file called home-assistant.log. If you restart the HA services whilst you tail -f home-assistant.log, you will see the log scroll infant of you whist it loads and hopefully the error.
EDIT: open two putty/terminal sessions so in one you can tail the log and the other you can restart the services.
I rebooted my machine and was able to get to the home assistant log
2018-12-21 15:33:07 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/configuration.yaml contains duplicate key "ip_port". Check lines 74 and 78.
2018-12-21 15:33:10 WARNING (MainThread) [homeassistant.config] Incomplete core configuration. Auto detected elevation: 0
2018-12-21 15:33:18 WARNING (Recorder) [homeassistant.components.recorder.migration] Database requires upgrade. Schema version: 7
2018-12-21 15:33:19 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=86 from 2018-12-21 23:16:09.718203)
2018-12-21 15:33:21 WARNING (MainThread) [homeassistant.loader] You are using a custom component for sensor.sonarr_upcoming_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-12-21 15:33:21 WARNING (MainThread) [homeassistant.loader] You are using a custom component for sensor.radarr_upcoming_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-12-21 15:33:23 WARNING (MainThread) [homeassistant.loader] You are using a custom component for media_player.alexa which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-12-21 15:33:25 ERROR (MainThread) [insteonplm] An aiohttp error occurred: Cannot connect to host hub1:25105 ssl:None [Name does not resolve] with status 999
2018-12-21 15:33:25 WARNING (MainThread) [insteonplm] Connection failed, retry in 1 seconds: Hub1
2018-12-21 15:33:27 ERROR (MainThread) [insteonplm] An aiohttp error occurred: Cannot connect to host hub1:25105 ssl:None [Name does not resolve] with status 999
2018-12-21 15:33:27 WARNING (MainThread) [insteonplm] Connection failed, retry in 2 seconds: Hub1
2018-12-21 15:33:29 ERROR (MainThread) [insteonplm] An aiohttp error occurred: Cannot connect to host hub1:25105 ssl:None [Name does not resolve] with status 999
2018-12-21 15:33:29 WARNING (MainThread) [insteonplm] Connection failed, retry in 3 seconds: Hub1
2018-12-21 15:33:30 WARNING (MainThread) [homeassistant.setup] Setup of insteon is taking over 10 seconds.
2018-12-21 15:33:31 WARNING (MainThread) [homeassistant.components.remote] Platform harmony not ready yet. Retrying in 30 seconds.
2018-12-21 15:33:33 ERROR (MainThread) [insteonplm] An aiohttp error occurred: Cannot connect to host hub1:25105 ssl:None [Name does not resolve] with status 999
2018-12-21 15:33:33 WARNING (MainThread) [insteonplm] Connection failed, retry in 5 seconds: Hub1
2018-12-21 15:33:34 WARNING (MainThread) [homeassistant.components.remote] Setup of platform harmony is taking over 10 seconds.
2018-12-21 15:33:34 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform ring is taking over 10 seconds.
2018-12-21 15:33:35 WARNING (MainThread) [homeassistant.components.camera] Setup of platform ring is taking over 10 seconds.
2018-12-21 15:33:38 ERROR (MainThread) [insteonplm] An aiohttp error occurred: Cannot connect to host hub1:25105 ssl:None [Name does not resolve] with status 999
2018-12-21 15:33:38 WARNING (MainThread) [insteonplm] Connection failed, retry in 7 seconds: Hub1
2018-12-21 15:33:46 ERROR (MainThread) [insteonplm] An aiohttp error occurred: Cannot connect to host hub1:25105 ssl:None [Name does not resolve] with status 999
2018-12-21 15:33:46 WARNING (MainThread) [insteonplm] Connection failed, retry in 11 seconds: Hub1
2018-12-21 15:33:47 WARNING (MainThread) [homeassistant.components.remote] Platform harmony not ready yet. Retrying in 30 seconds.
2018-12-21 15:33:57 ERROR (MainThread) [insteonplm] An aiohttp error occurred: Cannot connect to host hub1:25105 ssl:None [Name does not resolve] with status 999
2018-12-21 15:33:57 WARNING (MainThread) [insteonplm] Connection failed, retry in 17 seconds: Hub1
A quick look at that and I think the top error is the first to look at. The one about the configuration.yaml lines 74 & 78.
Start there and see if a service restart fixes it after you have sorted the two lines.
genius! thank you sir, had no idea an invalid config would cause the whole thing to crash…
Perfect! Glad to help
Always do a config check before restarting after a config change. The single most common thing to cause the frontend to not load is config errors.
