I’ve been avoiding upgrading my Hassio due to the fact that I did not have much luck in my last attempt (I was not able to upgrade to 0.101.3 - if I remember correctly, it was due to the changes in the authentication).
As I am further and further apart from the latest release, I want to give it a second try, but I do not want to break things, specially during the coronavirus lockdown
Any immediate advise regading this upgrade that you may want to share with me?
Personally I feel the same as you. Probably an unpopular opinion, unless there are new features you plan on using or something that isn’t particularly working I wouldn’t update. I keep telling myself not to update but when I finally get everything working I usually do, and then things break.
If you do upgrade, seeing as this would be a big one, I would expect that you’ll have plenty of fixing to do after.
I did go for the upgrade. Surprisingly it was done better than I thought it would be, as my hassio booted properly without any major difficulties.
I had to do some changes on my configuration files, namely the Google Assistant integration, as well as some devices that are using the wake on Lan feature.
I was using groups with views to organize my devices and sensors, but views are deprecated now, so I will have to learn lovelace in order to keep things tidy on my hassio.
Nonetheless, I still have some things to sort out, namely the webostv integration that does not seem to be working.
I am also having some trouble with the zwave refresh_entity that I am using to update my fgrm-223 percentage status. I am getting the following error:
Error executing script. Service not found for call_service at pos 2: Unable to find service zwave/refresh_entity
