Upgrading HA docker installation
I have HA installed as a docker image and it is telling me there is an upgrade available. I ran an interactive shell in my docker image and ran
pip3 install --upgrade homeassistant
as instructed on the docker tab at home-assistant.io/getting-started/ but it said it was already up to date:
root@mybox:/usr/src/app# pip3 install --upgrade homeassistant Requirement already up-to-date: homeassistant in /usr/local/lib/python3.4/site-packages Requirement already up-to-date: vincenty==0.1.3 in /usr/local/lib/python3.4/site-packages (from homeassistant) Requirement already up-to-date: pip>=7.0.0 in /usr/local/lib/python3.4/site-packages (from homeassistant) Requirement already up-to-date: jinja2>=2.8 in /usr/local/lib/python3.4/site-packages/Jinja2-2.8-py3.4.egg (from homeassistant) Requirement already up-to-date: requests<3,>=2 in /usr/local/lib/python3.4/site-packages (from homeassistant) Requirement already up-to-date: pyyaml<4,>=3.11 in /usr/local/lib/python3.4/site-packages/PyYAML-3.11-py3.4-linux-x86_64.egg (from homeassistant) Requirement already up-to-date: pytz>=2015.4 in /usr/local/lib/python3.4/site-packages (from homeassistant) Requirement already up-to-date: MarkupSafe in /usr/local/lib/python3.4/site-packages/MarkupSafe-0.23-py3.4-linux-x86_64.egg (from jinja2>=2.8->homeassistant)
Am I missing something? Should I just download a new docker image?
Thanks!
Ok, the answer is to pull the latest docker image. :slight_smile: I hope I helped someone else. :slight_smile:
Sorry, that should not have been part of the Docker upgrade instructions. You should indeed update the docker image.
I will try to make a PR to the docs when I have time. :slight_smile:
i just had a similar issue. It appeared to be upgrading successfully but the version reported by the UI never changed and the upgrade notification persisted. Waiting for a pull to complete now.(Yep. I can confirm that worked for me too. Thanks.)
