Hey,
I have tried to upgrade HAOS from 12.1 to 12.3 on my RPi 3 several times now and it fails every time.
Tried:
- Normal upgrade through web UI = fail
- Flashing new 12.3 and boot = fail
- Flashing new 12.1 and boot = success
and can restore backup thankfully
Logs from #2 are:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[17:07:12] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[17:07:13] INFO: Starting local supervisor watchdog...
2024-05-14 17:07:21.273 INFO (MainThread) [__main__] Initializing Supervisor setup
2024-05-14 17:07:21.323 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
2024-05-14 17:07:21.864 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: raspberrypi3-64
2024-05-14 17:07:21.884 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.05.1
2024-05-14 17:07:21.884 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
2024-05-14 17:07:22.180 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2024-05-14 17:07:22.191 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-05-14 17:07:22.194 INFO (MainThread) [__main__] Setting up Supervisor
2024-05-14 17:07:22.581 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2024-05-14 17:07:22.817 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2024-05-14 17:07:22.823 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2024-05-14 17:07:22.825 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2024-05-14 17:07:22.827 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2024-05-14 17:07:22.830 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2024-05-14 17:07:22.832 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2024-05-14 17:07:22.836 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2024-05-14 17:07:22.839 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2024-05-14 17:07:22.842 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2024-05-14 17:07:22.844 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2024-05-14 17:07:23.702 INFO (MainThread) [supervisor.host.services] Updating service information
2024-05-14 17:07:23.723 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-05-14 17:07:23.740 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
2024-05-14 17:07:24.014 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-05-14 17:07:24.179 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2024-05-14 19:07:24.381 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2024-05-14 19:07:24.392 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2024-05-14 19:07:24.602 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: [<AwesomeVersion CalVer '2024.05.0'>]
2024-05-14 19:07:24.629 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.05.0
2024-05-14 19:07:24.686 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
2024-05-14 19:07:25.930 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.05.0 - 172.30.32.5
2024-05-14 19:07:26.277 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: [<AwesomeVersion CalVer '2024.04.0'>]
2024-05-14 19:07:26.302 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.04.0
2024-05-14 19:07:26.370 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
2024-05-14 19:07:27.861 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.04.0 - 172.30.32.3
2024-05-14 19:07:27.864 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2024-05-14 19:07:27.945 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: [<AwesomeVersion CalVer '2023.12.0'>]
2024-05-14 19:07:27.974 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
2024-05-14 19:07:28.705 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
2024-05-14 19:07:30.700 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
2024-05-14 19:07:30.792 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
2024-05-14 19:07:30.817 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
2024-05-14 19:07:30.939 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
2024-05-14 19:07:32.725 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0 - 172.30.32.6
2024-05-14 19:07:32.797 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: [<AwesomeVersion CalVer '2024.03.0'>]
2024-05-14 19:07:32.827 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0
2024-05-14 19:07:32.890 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
2024-05-14 19:07:33.867 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0 - Host
2024-05-14 19:07:33.873 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
2024-05-14 19:07:33.926 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/raspberrypi3-64-homeassistant
2024-05-14 19:07:33.927 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant found.
2024-05-14 19:07:33.963 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
2024-05-14 19:07:33.964 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
2024-05-14 19:07:33.989 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
2024-05-14 19:07:34.049 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2024-05-14 19:07:35.138 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
2024-05-14 19:07:35.364 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.3 / BootSlot A
2024-05-14 19:07:35.388 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
2024-05-14 19:07:35.393 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
2024-05-14 19:07:35.401 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
2024-05-14 19:07:40.350 INFO (MainThread) [supervisor.store] Loading add-ons from store: 77 all - 77 new - 0 remove
2024-05-14 19:07:40.480 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
2024-05-14 19:07:40.576 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
2024-05-14 19:07:40.577 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
2024-05-14 19:07:40.577 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2024-05-14 19:07:40.577 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2024-05-14 19:07:40.578 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-05-14 19:07:40.579 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-05-14 19:07:40.579 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-05-14 19:07:40.580 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-05-14 19:07:40.581 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-05-14 19:07:40.582 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
2024-05-14 19:07:40.582 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-05-14 19:07:40.583 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-05-14 19:07:40.586 INFO (MainThread) [__main__] Running Supervisor
2024-05-14 19:07:40.615 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
2024-05-14 19:07:40.655 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2024-05-14 19:07:40.766 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
2024-05-14 19:07:40.767 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
2024-05-14 19:07:40.783 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
2024-05-14 19:07:40.783 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
2024-05-14 19:07:40.802 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2024-05-14 19:07:40.806 INFO (MainThread) [supervisor.core] Supervisor is up and running
2024-05-14 19:07:40.809 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
2024-05-14 19:07:40.810 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2024.5.3
2024-05-14 19:07:40.811 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant with tag 2024.5.3.
2024-05-14 19:07:40.812 INFO (MainThread) [supervisor.host.info] Updating local host information
2024-05-14 19:07:40.821 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-05-14 19:07:40.822 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-05-14 19:07:40.858 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-05-14 19:07:40.859 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-05-14 19:07:40.862 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-05-14 19:07:40.862 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-05-14 19:07:40.863 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-05-14 19:07:40.863 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-05-14 19:07:40.897 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-05-14 19:07:40.915 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-05-14 19:07:40.916 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
2024-05-14 19:07:40.916 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
2024-05-14 19:07:40.917 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-05-14 19:07:40.918 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-05-14 19:07:40.919 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-05-14 19:07:40.919 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-05-14 19:07:40.978 INFO (MainThread) [supervisor.host.services] Updating service information
2024-05-14 19:07:41.005 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-05-14 19:07:41.622 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-05-14 19:07:41.655 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2024-05-14 19:07:42.077 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-05-14 19:07:42.078 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-05-14 19:07:42.079 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-05-14 19:08:30.419 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/ttyACM1 - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2199020-if00
2024-05-14 19:08:30.432 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/007 - None
2024-05-14 19:08:34.697 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/009 - None
2024-05-14 19:08:34.706 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/ttyACM1 - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2199020-if00
2024-05-14 19:08:34.708 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-444' coro=<HomeAssistant._hardware_events() done, defined at /usr/src/supervisor/supervisor/homeassistant/module.py:326> exception=AwesomeVersionCompareException("Can't compare <unknown landingpage> and <CalVer 2021.9.0>")>
File "/usr/src/supervisor/supervisor/homeassistant/module.py", line 331, in _hardware_events
or self.version < "2021.9.0"
File "/usr/local/lib/python3.12/site-packages/awesomeversion/awesomeversion.py", line 172, in __lt__
raise AwesomeVersionCompareException(
awesomeversion.exceptions.AwesomeVersionCompareException: Can't compare <unknown landingpage> and <CalVer 2021.9.0>
2024-05-14 19:08:36.549 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/009 - None
2024-05-14 19:08:36.559 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/ttyACM1 - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2199020-if00
2024-05-14 19:08:36.562 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-448' coro=<HomeAssistant._hardware_events() done, defined at /usr/src/supervisor/supervisor/homeassistant/module.py:326> exception=AwesomeVersionCompareException("Can't compare <unknown landingpage> and <CalVer 2021.9.0>")>
2024-05-14 19:10:34.314 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/ttyACM1 - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2199020-if00
2024-05-14 19:10:34.329 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/001/009 - None
