Currently my HA is running on my RPI5 but im having some problems as i still run it on a SD card, so im looking to upgrade it and have some options and not sure which one or maybe something else.
HP T640 with Ryzen R1505G
HP T630 with AMD GX-420GI R7E
INTEL KIT NUC6CAYH CELERON J3455
FUJITSU ESPRIMO Q920 MINI I5-4570T
Something else that you reccomend in the range of €100 - €150,-
All will be upgraded with 16GB ram and around 500GB SSD
I want to install HAOS with proxmox on the new device but i have never used this so if you have any tips or guides for me that would be helpfull.
I have been running HAOS on proxmox with openmediavault, pihole, Heimdall dashboard and unifi controller on my HP T630 for over a year now with no issues. I did upgrade the ram to 16gb and the ssd. It also has some usb ssd’s hung off it for storage.
Been a fine machine.
As for tips just follow the guide linked above. Start with HAOS and then add what ever you need once you have that running.
It gives me step by step instructions and it looks good.
@Arh What size SSD you have internal? I was thinking of getting 480GB but also gonna use external drives for storage so maybe a 120GB internal is enough. Looking at what you run on it, i was planning about the same: HAOS, openmediavault and pihole
This piece (often available used for ~50$ in privileged countries) is all that’s necessary, even with only 8GB of RAM it can perform top notch and never let us down in over a year of service already.
The passive (no noise, no dust) cooling is great for a 24-7 system and the only thing that identifies the machine to be soon(2026) a decade old is the power consumption when idle (HA up and running) as it draws a solid 10W (peaks ~40W).
I’ve had success installing on a Lenovo ThinkCentre M710q. 8GB RAM version should be available for about £90. And easy to expand. I went with Lenovo, as generally they have good linux compatitbility.
