Just attempted the above using my usual procedure and upgrade failed. This is the output of the upgrade log. The first time I tried the upgrade the log suggested upgrading pip version which I did correctly
You are using pip version 19.0.3, however version 19.1 is available.
You should consider upgrading via the ‘pip install --upgrade pip’ command.
After the second attempt upgrading heres the output relating to cryptography errors. Has anything changed in the last two weeks that might be causing this issue and what I could do to overcome it.
Building wheels for collected packages: cryptography
Building wheel for cryptography (PEP 517) … error
ERROR: Complete output from command /srv/homeassistant/bin/python3 /srv/homeassistant/lib/python3.5/site-packages/pip/_vendor/pep517/_in_process.py build_wheel /tmp/tmptoa8mhbr:
ERROR: running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.5
creating build/lib.linux-armv7l-3.5/cryptography
copying src/cryptography/init.py -> build/lib.linux-armv7l-3.5/cryptography
copying src/cryptography/about.py -> build/lib.linux-armv7l-3.5/cryptography
copying src/cryptography/fernet.py -> build/lib.linux-armv7l-3.5/cryptography
copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-3.5/cryptography
copying src/cryptography/utils.py -> build/lib.linux-armv7l-3.5/cryptography
creating build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/init.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-3.5/cryptography/x509
copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-3.5/cryptography/x509
creating build/lib.linux-armv7l-3.5/cryptography/hazmat
copying src/cryptography/hazmat/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat
copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/mac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings
copying src/cryptography/hazmat/bindings/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/backends
copying src/cryptography/hazmat/backends/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends
copying src/cryptography/hazmat/backends/interfaces.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/serialization
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/utils.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings/openssl
creating build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/init.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ocsp.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x25519.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/encode_asn1.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
running egg_info
writing dependency_links to src/cryptography.egg-info/dependency_links.txt
writing src/cryptography.egg-info/PKG-INFO
writing requirements to src/cryptography.egg-info/requires.txt
writing top-level names to src/cryptography.egg-info/top_level.txt
reading manifest file ‘src/cryptography.egg-info/SOURCES.txt’
reading manifest template ‘MANIFEST.in’
no previously-included directories found matching ‘docs/_build’
warning: no previously-included files matching ‘*’ found under directory ‘vectors’
writing manifest file ‘src/cryptography.egg-info/SOURCES.txt’
running build_ext
generating cffi module ‘build/temp.linux-armv7l-3.5/_padding.c’
creating build/temp.linux-armv7l-3.5
generating cffi module ‘build/temp.linux-armv7l-3.5/_constant_time.c’
generating cffi module ‘build/temp.linux-armv7l-3.5/_openssl.c’
building ‘_openssl’ extension
creating build/temp.linux-armv7l-3.5/build
creating build/temp.linux-armv7l-3.5/build/temp.linux-armv7l-3.5
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fdebug-prefix-map=/build/python3.5-6waWnr/python3.5-3.5.3=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.5m -c build/temp.linux-armv7l-3.5/_openssl.c -o build/temp.linux-armv7l-3.5/build/temp.linux-armv7l-3.5/_openssl.o -Wconversion -Wno-error=sign-conversion
build/temp.linux-armv7l-3.5/_openssl.c:498:30: fatal error: openssl/opensslv.h: No such file or directory
#include <openssl/opensslv.h>
compilation terminated.
error: command ‘arm-linux-gnueabihf-gcc’ failed with exit status 1
ERROR: Failed building wheel for cryptography
Running setup.py clean for cryptography
Failed to build cryptography
ERROR: Could not build wheels for cryptography which use PEP 517 and cannot be installed directly
