I see that this version is not maintained anymore, so I would like to switch to the regular docker container. Can I do this without losing my current configurations in HA?
Just download new container, stop old container and start new container?
I cant find any information on this anywhere, your help is appreciated…
When I update I issue the following commands in the command line:
docker pull homeassistant/odroid-c2-homeassistant:stable # if this returns “Image is up to date” then you can stop here
docker stop home-assistant # stop the running container
docker rm home-assistant # remove it from Docker’s list of containers
docker run -d --name=“home-assistant” -e “TZ=Europe/Amsterdam” -v /home/homeassistant/.homeassistant:/config --restart always --net=host homeassistant/odroid-c2-homeassistant:stable # finally, start a new one
I assume that where I have now “homeassistant/odroid-c2-homeassistant:stable” it should be “homeassistant/home-assistant:stable”
the rest stays the same probably
If I enter docker rm home-assistant I remove my old container and when I start the new container it should use the available config files, but how can I backup my old container?
Also, the Odroid C2 is ARM64, should I pull a special container or is the :stable version good?
Since you use command line I would use rsync to simply make a copy at new location.
Updates may make Database changes which make rollback difficult or impossible. Having separate copy/backup ensures you can immediately restore if problems occur
You may also use backup tool in HA settings >> system >> backup. This simply creates a backup in the config folder. I prefer copy in separate folder
