Hi, I have a mix of Tradfri and Hue bulbs and units, and ZHA allows for OTA updates of Tradfri which is just peachy. But as Hue doesn’t publicly release their firmware, you have do some additional steps (if you have the firmware available.
I have gotten far, but I suppose I will need help to get to the finish line:
- I have ZHA perfectly setup, and I am able to control everything.
- I’ve added the following to my config yaml:
zha:
zigpy_config:
ota:
ikea_provider: true # Auto update Trådfri devices
ledvance_provider: true # Auto update LEDVANCE devices
otau_directory: /config/zigpy_ota # Utilize .ota files to update everything else
- I’ve added the file found here to the specified folder, which I believe is the newest version of the dimmer switch firmware (please correct me if I am wrong).
- Now, either the dimmer is going to update itself(?), or I have to force it. If I want to force it, how would I go about it? I suppose I have to send a cluster command, but which one?
